05 TJ MAP sensor problem - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-26-2016, 04:24 PM   #1 (permalink)
Member # 562730
I have a 05 TJ with the 4.0l, 42rle. it started idleing high and hunting alittle for idle (2k at start up then down to 1500 and finally 1100 once at temp, rpms found with a live streaming scanner) I first thought vacuum lean, checked no luck, then i replaced the IAC still no luck. its throwing no codes. Then i reset the ECU still no change. just for shits 'n' gigs i unpluged the MAP sensor and although the idle droped for a sec it acted exactly the same if it was unpluged or pluged in. (one time it ran really smooth so be it still at 1100 but i it only did it once) My question is befor i poke and hope with another part, is there another way to test the MAP or what else could cause the idle issues? thanks guys!
TJ2021
Keep the shinny side up and the greasy side down
TJ2021 is offline   Reply With Quote Quick reply to this message
