98 TJ - Steering wheel play - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-25-2016, 12:06 AM   #1 (permalink)
Member # 702905
So after replacing the steering box (Red Head Steering) and all the linkage (Currie Currectlync), I still have some play in the steering wheel that seems to be getting worse. Theres roughly 2 inches of play in the steering wheel before the tires actually start to move, and there are audible "thunks" between each end of the play. The upper sector shaft seems to be okay, there isnt any play between the wheel itself and the shaft under the dashboard. I haven't really checked the lower yet, but when I replaced the steering gearbox it seemed to be okay. I tried tightening the coupler between the upper and lower shafts but its rock solid. Anyone got any ideas?
FalloutMaster is offline   Reply With Quote Quick reply to this message
Old 10-26-2016, 08:49 PM   #2 (permalink)
Member # 199594
check your u joint caps on your steering column
mike Zeko is offline   Reply With Quote Quick reply to this message
Old 10-26-2016, 09:36 PM   #3 (permalink)
Has Training Wheels
Da-Tinman's Avatar
Member # 112488
check the pitman arm nut, mine will back off every once in a while.
The problem with the shallow end of the gene pool? No room for depth charges.
Da-Tinman is offline   Reply With Quote Quick reply to this message
Old 10-28-2016, 02:35 PM   #4 (permalink)
Member # 702905
I already checked them and they dont seem to have any play.
Just tried that, pitman arm nut got a little tighter but it didn't eliminate or affect the steering play at all. I had my dad turn the wheel back and forth while I was under the Jeep watching the steering box and noticed that the steering shaft turns quite a bit before it engages the pitman arm. As a matter of fact, I can reach up and grab the steering shaft at the input on the steering box, with my hand, and turn it nearly a quarter turn before it grabs and I cant turn it any more. I'm not impressed with this steering box at all. The first 2 steering gears Red Head sent me leaked badly, this 3rd one doesn't leak but it seems to be getting looser over a period of just 6 months? I don't know how much play should be in a stock steering box, but this seems excessive to me.
Old 10-28-2016, 04:30 PM   #5 (permalink)
Member # 67606
Ball joints?
Kickin'Chicken is offline   Reply With Quote Quick reply to this message
Old 10-28-2016, 06:15 PM   #6 (permalink)
Member # 76990
Take the pitman arm off and look at the splines, Also some times the nut bottoms out before the splines get pushed up on the splines tight. I have found this quit a few times, The pitman arm dances around on the sector shaft.
superglock is offline   Reply With Quote Quick reply to this message
Old 10-28-2016, 09:42 PM   #7 (permalink)
NERD
gtxracer's Avatar
Member # 25303
Like superglock said, look at your steering shaft splines.
From what you're saying, it sounds like the steering box needs adjusted. There's a nut on the top of the box, as it's installed, with a set screw in the middle. Loosen the nut without turning the set screw, then turn the set screw clockwise 1/4 turn at a time until the steering slop is gone. Once you have it set, tighten down the nut while making sure the set screw doesn't turn from where you set it.
97 TJ Build:
2013 Raptor SuperCrew Tow Rig
Porsche
Fab Parts:
PNW Shock Tuning:
gtxracer is offline   Reply With Quote Quick reply to this message
Old 10-29-2016, 01:08 PM   #8 (permalink)
Member # 702905
Thanks, this ended up fixing the problem. I called RedHead and they advised against adjusting it and tried to blame the steering slop on my suspension/alignment lol. Easy fix, thanks again.
