CJ-7 truck - Page 10 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-22-2019, 05:57 AM   #226 (permalink)
today
fredycruger's Avatar
Member # 225557
Originally Posted by 92 Green YJ View Post
Looking good! If you havenít purchased the gauges yet, you may want to check out speedhut.com. Iím planning to use one of their all in one CJ style gauge clusters for my build. This one
https://www.speedhut.com/gauge/GCJ5....el,-Temp,-Tach
Nice thing with Speed hut is you can completely customize the gauge sets however you want. Color, dial, font, etc. I have a set of their gauges in my 71 Charger and they are super nice.
i have the gauges already except the speedo
the speedo will be speedhut GPS 4" Mph/Rpm combo
i decided to take easy road out and not build the center console at this time
noticed pretty big leak from the tranny
it had piece of cardboard under neath and i couldnt see it till now
gotta take the pan down and see whats up
fredycruger is offline   Reply With Quote Quick reply to this message
Old 06-22-2019, 08:16 AM   #227 (permalink)
today
Member # 225557
ordered bunch of shit to finish up the dash
cheap head unit will be behind glove box, one i got is only 3-3/4" deep
got 2 RF speakers 5.25",
my dash doesnt have any mounting studs . it was cheapest blank dash i could find 130$
i found template for the speakers so ill use that for layout
ill weld some bolts to the back and use that as mounting studs
some rubber bumpers for glove box lid and lock
Old 06-22-2019, 08:28 PM   #228 (permalink)
Member # 16505
Send a message via AIM to 92 Green YJ Send a message via Yahoo to 92 Green YJ
Nice! Dash is looking good!
92 Jeep Wrangler.
lots of mods with lots more to come. Just Empty Every Pocket!
92 Green YJ is offline   Reply With Quote Quick reply to this message
Old 06-24-2019, 04:58 AM   #229 (permalink)
today
Member # 225557
thanks
welded some small bolts to back of the dash to hold speakers.
found template online for speaker cut out and used that for layout
dash is done and ready for paint
finished few small things on the the rollcage and its also ready for paint
Power washed and degreased the whole truck and bed
im masking off the seams, and ill apply seam sealer to the tub tonight so it can cure before applying raptor liner
Old 06-25-2019, 04:21 AM   #230 (permalink)
today
Member # 225557
its not stupid if it works right?
took somebody's advice from here and taped around where you seam sealing
looks much better in the and
and some progress on the new place
LoL i was hoping to start framing in march
Old 06-25-2019, 10:38 AM   #231 (permalink)
today
Member # 225557
inner fenders done in raptor liner
took 1 Quart to do that
could use another coat, still got 4 qts left, and i need to do Tub,
roll cage,bottom of hood and one more coat on fenders..
Best way to store respirator when its hot out
Old 06-26-2019, 04:49 AM   #232 (permalink)
today
Member # 225557
tub raptor lined
Cage and hood also done
Old 07-01-2019, 05:04 AM   #233 (permalink)
today
Member # 225557
ended up getting amazon GPS gauge
and spent sunday doing bodywork
Old 07-08-2019, 05:40 AM   #234 (permalink)
today
Member # 225557
Paint
gotta get more paint .
still have to do hard top half and full doors
i first sprayed tub hood fenders
it came out great for being sprayed outside , love the new gun, it lays down the paint nicely
but i fucked up big time
spraying the bed, windshield frame and tailgate.
i run out of daylight by the time i sprayed the bed
moving onto windshield , knowing there is lot of curves i turned down the gun,so it spray less paint .
well i turned the knob wrong way and it was dumping the paint out .
by the time i realized, paint was running down everywhere
most likely ill have to respray the whole truck but for now ill put it together and spray it as whole
Old 07-08-2019, 05:45 AM   #235 (permalink)
today
Member # 225557
kind of wished i went with gloss instead of matte paint
im doing hinges and bolts gloss black
Old 07-08-2019, 05:51 AM   #236 (permalink)
Member # 4979
I like that color.
88 Samurai - Trail tested
88 Samurai - Work in Progress, Street/Trail
95 Sidekick 4 door - Kids wheeler/DD
97 Jeep TJ - Work in Progress, Street/Trail
05 F150 - Tow rig
98 Tahoe - Backup Tow Rig/DD
mrstang01 is offline   Reply With Quote Quick reply to this message
Old 07-08-2019, 10:23 AM   #237 (permalink)
today
Member # 225557
thanks man, i like it too
i ordered another gallon of paint .ill spray the whole jeep again once is assembled
glued the windshield glass in
decided to go with YJ style frame and glass , i hate those CJ gaskets you have to force the window in
ran 2 v shaped beads one in channel one on the rubber gasket
set the window down , centered it ,ran another bead of glue in the gap between glass and frame and set decorative gasket in
i have few spots where the glue came out a little ,its tedious process not to get the glue everywhere
Old 07-09-2019, 04:19 AM   #238 (permalink)
today
Member # 225557
Old 07-12-2019, 08:28 AM   #239 (permalink)
today
Member # 225557
puting it all back together
swapped over windshield wipers,motor and linkages motor had bunch of rope tangled up in it
installed gauges ,still need to wire the dash and its ready to be put back in
Old 07-15-2019, 05:52 AM   #240 (permalink)
today
Member # 225557
FUCK FUCK FUCK
installing hood latches
small nut falls down inside of engine bay
right into alternator
2 hours later .without the nut . i say fuck it and let the engine run
and few minutes later i hear ping ping ping AND NUT FELL OUT on its own.
changed the belts in the process so not complete waste of time
real tires
Old 07-15-2019, 12:08 PM   #241 (permalink)
today
Member # 225557
Old 07-17-2019, 04:06 PM   #242 (permalink)
Member # 859684
You are down to the short rows. Can't wait to see it finished
Shorthood is offline   Reply With Quote Quick reply to this message
Old 07-18-2019, 06:45 AM   #243 (permalink)
today
Member # 225557
yeah few small things to pass inspection and paint the rest of the jeep.
ebrake,windshield washer bottle, horn
front driveshaft and xcase shifter , tidy up behind the dash ,bolt seatbelts in and switch belt buckles
Old 07-22-2019, 06:14 AM   #244 (permalink)
today
Member # 225557
Old 07-22-2019, 11:39 AM   #245 (permalink)
nice roach.
jhama78's Avatar
Member # 3377
Send a message via AIM to jhama78
Looks killer man!! Nice work.
-j-rOd
wear life like a loose garment
84 Toy Farm Beater
88 4Runner Beach Ride
11 Tundra Double Cab Rock Warrior
jhama78 is offline   Reply With Quote Quick reply to this message
Old 07-23-2019, 05:10 AM   #246 (permalink)
today
Member # 225557
thanks man its been long 6 years since i started
im glad all the painting and rust grinding is done
Old 07-23-2019, 07:21 AM   #247 (permalink)
nice roach.
jhama78's Avatar
Member # 3377
Right after I posted yesterday I saw this thing on the Ruff Stuff Specialties IG page.
-j-rOd
84 Toy Farm Beater
Old 07-24-2019, 12:46 PM   #248 (permalink)
today
Member # 225557
yeah they have few pics there, i used bunch of theirs brackets.
yesterday i filled up and calculated millage and im getting around 18MPG and diesel is 3.08c/gal
Old 07-24-2019, 07:23 PM   #249 (permalink)
Member # 16505
Nice job! That came out killer!
92 Jeep Wrangler.
Old 07-25-2019, 08:53 AM   #250 (permalink)
Member # 548137
sweet build, came out nice
denverd1 is offline   Reply With Quote Quick reply to this message
