Is anyone still producing a TJ front-half kit? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-21-2018, 06:44 PM   #1 (permalink)
Member # 343466
It's still a popular thing to do, but as far as I know, nobody is producing these.
I'm going to get back a larger refund than I expected (thanks Trump), and am considering just going to full hydro.
wvjeepguy81 is offline   Reply With Quote Quick reply to this message
Old 01-21-2018, 07:15 PM   #2 (permalink)
GIJEEPN
Member # 135100
Send a message via ICQ to DriverJC Send a message via Yahoo to DriverJC
Glad you are getting a refund, lol...
I wouldn't mind having a front half kit, but I haven't found anyone selling one.
If you find anyone selling one, let me know.
Joel
DriverJC is offline   Reply With Quote Quick reply to this message
Old 01-21-2018, 08:41 PM   #3 (permalink)
Member # 343466
Joel
Yeah, I probably should just stick with hydro assist. Even with having a WJ pump and a custom rez already, the full hydro parts are still going to run over $1,000.
I should put that money towards better shocks or something.
Old 01-22-2018, 04:39 AM   #4 (permalink)
Member # 197896
What exactly do you mean by a front-half kit? If you mean cutting off the front frame rails and adding some type of modified frame (like a back half), then they aren't that popular. Doing a front suspension modifications to lengthen wheelbase and improve up travel are significantly more difficult then doing the back due to all of the complications and interactions with steering components, track bars, etc.
Going full hydro takes away some of that problem, but it is still more difficult than the back. There are only three places I know that have something similar to this, and only one of them is regularly produced. TnT Customs makes a steering box relocation kit that allows you to push your front axel forward 2-3 inches and is fairly complete with everything you need to relocate the box, assuming you have a suspension that allows you to push it forward already - or they have the parts to do that as well.
MadMac on here has a kit of parts to make a new front frame section, but I am not sure how available they are. When I looked into a couple years ago he wasn't making them, but sent me a message a few months later that he was thinking about making another run of them. It's just the frame, so you are going to have to figure everything else out yourself.
Brave Motorsports is the only other one I know of, and I don't think it's a production item for them either. I saw it on one of their builds here on Pirate and contacted Dave. We worked out a deal and he supplied a couple of welded front frame horns, plates for the steering box and fish plates to strengthen the frame splice. I was very happy with the quality and design, but again you are basically on your own with figuring out how to implement things once you weld on the frame extensions. I've stretched the front of my TJ by almost 6", but it's still not finished yet. It required a new steering box, new radiator & mounts, new links, new winch mount and a whole lot of other changes, so it is definitely not something I would recommend for everyone unless you are really committed in terms of $ and time. Build thread is here: https://www.pirate4x4.com/forum/jeep-...etch-more.html
but Photobucket ruined all the pics and I have not had time to reload all of them yet
giles45shop is offline   Reply With Quote Quick reply to this message
Old 01-22-2018, 09:22 AM   #5 (permalink)
Member # 343466
Yeah, the transition pieces are the main thing, to make it look clean and to simplify it. I recently backhalfed my frame with the Artec kit and I'm really happy with the results.
Having straight tube between the motor mounts and the grill area would make it way easier to mount suspension stuff, and then I'd want to sink my winch in between the rails and shorten the front frame rails.
Old 01-22-2018, 12:14 PM   #6 (permalink)
GIJEEPN
Member # 135100
Since you posted this I've been brain storming what it would take to do this.
Going off what you said you wanted, ( cutting out the wheel arch and running straight frame rails from the motor mounts forward ) I don't see how this would be a benefit, ( assuming what I'm looking at on the frame drawing in the manual are actually engine mounts ). the engine mounts are attached the to frame aft of the wheel well arch. Removing this arch would give you less upward travel if you kept the axle within 3-4" of the stock full bump position.
However, If you extended the frame rails from the top of the arch forward to the natural end of the frame, you would indeed have a lot more space in which to articulate the axle ( roughly 3" more up-travel prior to contacting the frame rails ). However, this method would create it's own problems. For one, for every inch you move those frame rails up you will have to relocate the Grill, Radiator, Engine, Transmission, Fenders, and Body upwards by the same amount.
Now if you were to perform this modification and moved the grill, and radiator, upwards the required 3" you could conceivably install a 3" body lift to line up the body/fenders/grill/radiator and removed the engine fan to install an electric one, you could make it work rather inexpensively.
If you decide to do this, take copious amounts of notes and pictures so we can see how you went about it and maybe try to follow suit. lol. Yup at this time I don't want to be the guinea pig.. lol
BTW: why is not doing a front half kit stopping you from going with full hydro steering?, or am I reading between too many lines. lol
Joel
Old 01-22-2018, 01:26 PM   #7 (permalink)
Member # 343466
Joel
It's not keeping me from doing going to hydro, but it would make packaging for the front stretch easier. Most guys on here anymore just cap off the frame and run tubes to finish it out, but I don't have a bender.
Old 01-22-2018, 04:47 PM   #8 (permalink)
Member # 197896
Joel
That's kind of what I did in reverse. The Jeep had a 2"body lift, but when I re-did the frame rails to come out straight from the wheel well hump in the frame the grill was basically sitting on the frame rails with no lift. I ended up attaching the grill to the hoop I welded to the frame rails instead of a central mount like the factory had. At some point I figure I'll re-do the body mounts and move them upward to eliminate the body lift completely
Joel
Yep, All of this stuff has to move/be re-designed and I can tell you from personal experience that "inexpensive" is not a word you would use at any time in reference to a front frame stretch
Old 01-22-2018, 05:39 PM   #9 (permalink)
GIJEEPN
Member # 135100
LOL... I hear you there.
Old 02-05-2019, 12:11 PM   #10 (permalink)
delsolcharlie's Avatar
Member # 227618
Its only a year old ...but just saw this on facebook and instagram. Motobilt just released a rendition of a TJ/LJ front half kit!!!
Facebook : https://www.facebook.com/dan.dubose/...57151879682052
Instagram: https://www.instagram.com/p/BtgvLxmD...ns_share_sheet
delsolcharlie is offline   Reply With Quote Quick reply to this message
