Oil slut my jeep is !! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-14-2018, 07:17 AM   #1 (permalink)
Member # 852586
Guys I have a 2008 Jeep Wrangler unlimited that is my daily driver. It has 125,000 miles on it and it uses 1qt of motor oil every 1000 miles. Any advice? Just keep toping it off? Any product additives that would be good to use? Donít really know what to do....???
WindrockRZR is offline   Reply With Quote Quick reply to this message
Old 08-14-2018, 09:01 AM   #2 (permalink)
Member # 805850
Figure out what is happening to the oil.
toximus is offline   Reply With Quote Quick reply to this message
Old 08-14-2018, 09:17 AM   #3 (permalink)
Member # 178200
If it's not leaking out, the engine is burning it. Could be leaking into the combustion chambers through the valve seals/guides or the rings or cylinder walls may be worn out causing it to seep past. A cylinder leak down test will pinpoint the rings/cylinders if those are the issue, and if those pass the test, it's safe to assume it's in the heads or PVC system somewhere. Good luck and let us know what you find.
SLOWPOKE693 is online now   Reply With Quote Quick reply to this message
Old 08-14-2018, 09:31 AM   #4 (permalink)
gt1guy's Avatar
Member # 236179
Just screw a new filter on every third quart.
Does it smoke at all? Does it still run good? If it runs good and doesn't smoke, keep it topped off and enjoy.
I wouldn't try any of those "mechanic in a can" additives. You can't un-wear-out worn out parts.
Kevin
gt1guy is offline   Reply With Quote Quick reply to this message
Old 08-14-2018, 10:36 AM   #5 (permalink)
Member # 9994
what oil and grade are you using?
1984 CJ-8
1986 CJ-7
1981/1992 CJYJ
1994 RAM 1500 4x4
Custom Fabrication Parts:
jeepnmatt is offline   Reply With Quote Quick reply to this message
Old 08-14-2018, 03:11 PM   #6 (permalink)
gregj50's Avatar
Member # 151818
Misleading headline!!!
Youíre lucky to get 100,000 out of the minivan motor!!
Keep topping it off.... prep for LS swap!!!
gregj50 is online now   Reply With Quote Quick reply to this message
Old 08-14-2018, 04:25 PM   #7 (permalink)
Member # 79509
1qt per 1000 miles is acceptable for fiat
Black Sheep is offline   Reply With Quote Quick reply to this message
Old 08-14-2018, 06:48 PM   #8 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
You're as helpful as flood in a fizzys factory.
One of the great achievements of science has been, if not to make it impossible for intelligent people to be religious, then at least to make it possible for them not to be religious. We should not retreat from this accomplishment.
Salesmen and women. God sells to the ignorant.
SanDiegoCJ is offline   Reply With Quote Quick reply to this message
Old 08-14-2018, 06:55 PM   #9 (permalink)
Member # 852586
Doesnít leak, doesnít smoke , runs good. 5w-20 Mobil 1 synthetic. Just using oil like crazy! Pulls my RZR
Old 08-14-2018, 06:57 PM   #10 (permalink)
Member # 805850
Since when has non-hardcore become the noob section?
Old 08-14-2018, 07:04 PM   #11 (permalink)
Member # 133684
He just cunted you. Notice he doesn't have any advice?
brmpipes is offline   Reply With Quote Quick reply to this message
Old 08-14-2018, 07:05 PM   #12 (permalink)
gregj50's Avatar
Member # 151818
I would switch to 10/30.
5/20 was a gas mileage gimmick for the dealers!!!
Old 08-15-2018, 11:18 AM   #13 (permalink)
Member # 852586
Thanks. I thought about trying that to see if it would help any. I feel better about switching to the heavier weight now.
Old 08-15-2018, 01:48 PM   #14 (permalink)
Member # 9994
i'd switch to 10w30 Rotella T5 and see if that helps.
the detergents in this oil will help clean things like the oil control rings and could help reduce consumption
1984 CJ-8
1986 CJ-7
1981/1992 CJYJ
1994 RAM 1500 4x4
Old 08-15-2018, 05:25 PM   #15 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
Try reading the forum rules, then follow them.
Ok for now many are still trying to get the forum changed to hardcore/the rest. Whatever happens this new forum is not going to allow the flaming and whining.
So be that as it may no flaming, no whining, answer stuff, or don't post.
Old 08-15-2018, 07:25 PM   #16 (permalink)
Member # 191442
The 3.8l is a pushrod engine, the valve stem seals are fairly easy to replace. Rockauto will have them and some valve cover gaskets, cheap, too.
The older 3.8's and 3.3's used 10w30, should slow consumption down vs 5W20.
Marty, SoCal is offline   Reply With Quote Quick reply to this message
Old 08-15-2018, 08:53 PM   #17 (permalink)
Member # 852586
Thanks for that info!
Old 08-16-2018, 09:32 PM   #18 (permalink)
Member # 805850
Then don't whine about my post and help the guy.
