8.8 rear w/disc swap--Master Cyl - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-14-2018, 01:02 PM   #1 (permalink)
Member # 13786
Got everything in and welded, pedal is a little spongy but stops. Would like to get a real pedal. Mater cylinder upgrade recommendations?
KWTMECH is online now   Reply With Quote Quick reply to this message
Old 08-15-2018, 04:01 AM   #2 (permalink)
Here's Johnny!
frostytj's Avatar
Member # 12867
What vehicle and what is the current booster and MC?
Sounds like you need to bleed the brakes better.
Buy the ticket, take the ride.
frostytj is offline   Reply With Quote Quick reply to this message
Old 08-15-2018, 08:11 AM   #3 (permalink)
lpukas2's Avatar
Member # 55139
yeah, never had an issue with my 8.8 in a TJ with stock crap
lpukas2 is offline   Reply With Quote Quick reply to this message
Old 08-15-2018, 08:27 AM   #4 (permalink)
Member # 13786
1993 YJ feels like it needs more pedal. Doesn't feel like it really wants to stop, just slow down. Brakes are bled just fine, fluid nice and clean.
Old 08-15-2018, 08:28 AM   #5 (permalink)
I'm not your buddeh
D_JEEPER's Avatar
Member # 99624
Ran the stock one MC in my TJ when I swapped in a Disc brake 8.8 from a drum brake D35.
Make sure your bleeder screws are on top. I made the mistake of swapping calipers and the bleeder screw was below the brake line, causing an air pocket that would not bleed out, and similar issues.
MOLON LABE
If I was an FBI agent on one of these stings, I wouldn't be able to resist building up a suicide vest rigged with confetti cannons.
ALLAHU ACKBAR! "pop"
D_JEEPER is offline   Reply With Quote Quick reply to this message
Old 08-15-2018, 11:22 AM   #6 (permalink)
Here's Johnny!
frostytj's Avatar
Member # 12867
You could upgrade the booster and MC to the dual diaphragm setup from the 1995 YJ. That should be an improvement over what came on the 1993.
I don't think spongy brakes are due to the MC unless you damaged it while bleeding the brakes. Its typically air still in the system somewhere.
Old 08-15-2018, 12:16 PM   #7 (permalink)
Member # 13786
So on with my original question... master cylinder upgrade? from disc/drum to disc/disc. In my research I came up with a builder that uses a MC from a 78 Ford with 4 wheel disc, but I found is doe snot fit correctly without bending the crap out of the clamp that holds the lid tight. I'm thinking I need more than a 1'' piston in the MC and a bigger reservoir would be nice for the rear
Old 08-15-2018, 12:33 PM   #8 (permalink)
Here's Johnny!
frostytj's Avatar
Member # 12867
Your booster isnít meant to drive a bigger bore MC. You will get the firm short pedal you seem to be after at the expense of less PSI at the calipers. But good luck.
