Dana 44 axle tag confusing - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-15-2018, 10:06 PM   #1 (permalink)
Member # 854336
Just picked up on a '73 CJ5 project. No engine...
The rear axle tag is there, but I cant find much info by web search. It has a second tag indicating use Limited Slip lube.
999431
47-11 4.27
4.27 makes sense; 4.27 gears. The extra tag for limited slip lube would have to guess a Trac-Loc or Powr-loc. But the 999431 and 47-11 numbers dont match what I can find on the web.
Any way to tell if it is Trac-Loc or Powr-Loc without pulling the cover?
RNE228 is offline   Reply With Quote Quick reply to this message
Old 08-15-2018, 10:33 PM   #2 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
47-11 is pinion and ring tooth count.
Idk what the other ## is, shouldnt be a bom.
Usually is 2 tags, obviously the limited slip lube is its own.
The other is about 1.25" long and has 47-11 over the 4.27.
Old 08-15-2018, 10:35 PM   #3 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Track lock should have some friction action all the time.
Power lock should be easy to slip until some psi is applied from resistance
Old 08-16-2018, 09:20 AM   #4 (permalink)
I'm not your buddeh
D_JEEPER's Avatar
Member # 99624
New vehicle, pull the cover. You never know what is in there vs what the previous owner left on the diff cover bolts
MOLON LABE
If I was an FBI agent on one of these stings, I wouldn't be able to resist building up a suicide vest rigged with confetti cannons.
ALLAHU ACKBAR! "pop"
D_JEEPER is offline   Reply With Quote Quick reply to this message
Old 08-16-2018, 12:11 PM   #5 (permalink)
Member # 854336
I was trying to find out from the axle tags.
I cant do much with it where it is parked now; when I get it up to the garage I can pull the covers. It will eventually need fluid changes at a minimum too.
Old 08-16-2018, 12:16 PM   #6 (permalink)
Member # 854336
I pulled the tags(unbolted).
The short tag only said to "use limited slip lube"
The longer number on the main tag did not make sense; fom what I could find by web search, the BOM # has a -"number" on the end.
Part of the fun of figuring out a new rig
Old 08-16-2018, 12:16 PM   #7 (permalink)
I'm not your buddeh
D_JEEPER's Avatar
Member # 99624
Yeah, with an unknown as vital as differential status, I would take the $15 hit for RTV and gear oil to verify it wont explode on me at an inopportune time
MOLON LABE
Old 08-16-2018, 07:21 PM   #8 (permalink)
CSP
Member # 1533
What are you expecting to find out from the tag? It's a Dana 44 with 4.27 gears, which is exactly what was offered in any '72-75 CJ.
The BOM on the axle tube will tell you exactly every detail about it.
CSP is offline   Reply With Quote Quick reply to this message
Old 08-17-2018, 10:57 AM   #9 (permalink)
Member # 854336
Just curious if it has TracLock or PowrLok. It'll be a couple of weeks before I can get it in the garage and remove the cover.
Old 08-17-2018, 12:03 PM   #10 (permalink)
Member # 13786
The tags don't mean shit after 45 years...especially on a Jeep
KWTMECH is offline   Reply With Quote Quick reply to this message
Old 08-17-2018, 03:06 PM   #11 (permalink)
Member # 854336
Very true...
