Hydro assist steering coolers - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-05-2018, 09:37 AM   #1 (permalink)
Member # 7624
Send a message via AIM to offroadman83
I've searched my brains off and can't seem to find much especially on jeeps with hydro assist and what cooler they are running. I'm gonna be running a very sweet AGR pump with WTO ram pushing 40s on superdutys. The only think I lack is a steering cooler and Im just unsure of what to get. Seen everything from the heat sink style to to tube and fin and even plate but everyone seems to have some kind of problems with all certain types. I figured I would put this into the jeep specific are as well for mounting pictures and what works best for our type of rigs. My thinking is running old school tube and fin with a fan..........Keep in mind I live in one of the hottest regions of the USA ..........absolute hell. Hopefully can get some good tech here.
2000 tj with stuff
offroadman83 is offline   Reply With Quote Quick reply to this message
Old 09-05-2018, 11:05 AM   #2 (permalink)
Member # 34410
I am running a simple tube and finned U shaped cooler, im only pushing a stock box, stock pump and tapped box. I was careful to match the lines all to the same size (3/8) haven't experienced any issues as of yet. For mounting I have it mounted inside the grill with some rubber isolators and zip ties.
1991 YJ 4.0 AX15 D300
D44 front D70 rear SOA on 37's
UstabeaRenegade is offline   Reply With Quote Quick reply to this message
Old 09-05-2018, 03:07 PM   #3 (permalink)
49willys_mogon's Avatar
Member # 78325
Run a heat sync
Howes reference guide. What's nice about this flow chart is you can visualize each segment of hose and how it applies to any application. I have a bunch of prints so when I need to build a system and buy fittings hose types I can easily check them off.
Hose selection: I prefer the astectics of black but it's off by about 50 degrees at the high end of heat requirements from blue. As much as I hate push lock stuff the ID is better for flow on the non pressurized side and select fittings have 3 barbs vs 2. The aeroquip teflon hose Im running from the output of the pump to the hydroboost to steering box is really nice. Extremely high temp rating but cannot be kinked at all.
[/QUOTE]
49willys_mogon is offline   Reply With Quote Quick reply to this message
Old 09-15-2018, 03:46 PM   #4 (permalink)
Member # 36385
I ran a tube and fin one with no issues with assist or full hydro. IF you go heat sink, I have a brand new one Ill sell ya. I dont need it.
Big4x4Rides is offline   Reply With Quote Quick reply to this message
Old 09-15-2018, 03:52 PM   #5 (permalink)
Member # 690690
I run my Hydro boost and Hydro assist through a tube and fin from PSC, No issues even in the AZ heat.
bkh98 is offline   Reply With Quote Quick reply to this message
Old 09-15-2018, 04:49 PM   #6 (permalink)
giles45shop's Avatar
Member # 197896
I can't tell you if it works or not since I'm still building, but here's my set-up running an AGR/Steerco CB pump, new design Steerco reservoir and a Russell 15" heat sink cooler. Line from reservoir to pump is -10 Fragola push lock (rated for vacuum), lines from box to cooler and back to reservoir are -8 Fragola push lock. The cooler is held to the grill brace with hose clamps. I used a carbide burr in a die grinder to put some semi-circular slots in the backside cooler fins that are the same angle as the grill brace so there is enough room to fit the cooler in front of the grill brace and it won't slide around.
You want to keep the cooler as low as possible, definitely below the reservoir so it is the highest point in the system. I compromised on mine as I didn't want it blocked by the winch, but it is still about 4" below the reservoir. The other cooler in the grill is one of my transmission coolers.
The return line from the box has a 90 that points towards the passenger side and runs along the bottom of the grill and then up to the passenger side of the cooler, which has a -8AN sweep 90 pointed straight down. The driver side of the cooler has another 90 pointed straight down and the hose exits the slotted area in the grill on the driver side and back to the reservoir.
I don't have any pictures of the cooler hose routing handy, but it's pretty self-explanatory. Here's a picture of the cooler mount, reservoir mount and feedline to pump.
giles45shop is online now   Reply With Quote Quick reply to this message
Old 09-15-2018, 07:20 PM   #7 (permalink)
Member # 7624
Go figure i just bought a heat sink style today....
Sent from my SAMSUNG-SM-G891A using Tapatalk
2000 tj with stuff
Old 09-17-2018, 06:00 AM   #8 (permalink)
today
fredycruger's Avatar
Member # 225557
dibs on the cooler
fredycruger is offline   Reply With Quote Quick reply to this message
