Stand alone 5.3 in a JKU? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-24-2018, 06:26 PM   #1 (permalink)
Member # 856324
Iím wanting to put a 5.3 in my JKU, I want to pull all of the Jeep computers and wiring out, including the factory hvac, etc, basically just keep the body, frame, and what trim I can on the inside, then replace with gm computers, parts, wiring etc, has anyone done this with their JK? Iím sure itís more complicated then it sounds.
This is and will be my daily driver, so I would like to keep power steering and brakes, as well as standard safety features if possible. I donít care if I have to replace gauges and stuff.
SwampDonkeyjku is offline   Reply With Quote Quick reply to this message
Old 09-25-2018, 06:57 AM   #2 (permalink)
Pirate hooker
sidewaysstarion's Avatar
Member # 349714
Ok, what year is the JKU?
sidewaysstarion is offline   Reply With Quote Quick reply to this message
Old 09-25-2018, 06:58 AM   #3 (permalink)
Master Tinkerer
oldtimingman's Avatar
Member # 75774
Yes its been done...., not easy
suggest you look on the JK forum
Tons are your friends.........
oldtimingman is offline   Reply With Quote Quick reply to this message
Old 09-25-2018, 08:33 AM   #4 (permalink)
Member # 856324
Is a 2011 Sahara
Old 09-25-2018, 09:27 AM   #5 (permalink)
Blown7's Avatar
Member # 63754
It would be easier to add a FCA engine. If you go that route contact Modern Muscle they can use the FCA engine PCM for that engine and run a second old PCM to power all the instruments and can bus.
1977 CJ7, 401 AMC 6-71 GMC Blower, 16 Injector EFI,
[COLOR="Yellow"][SIZE="3"]My Build [/SIZE]
[/COLOR]
2007 Jeep Grand Cherokee SRT8 for the road.
Blown7 is offline   Reply With Quote Quick reply to this message
Old 09-25-2018, 10:05 PM   #6 (permalink)
Pirate hooker
Member # 349714
https://www.bruiserconversions.com/jk-engines
They have a custom setup that uses the stock ecu to run an LS motor, that would probably be the easiest for your goals.
