Wrangler 05-06 fuel pump in 97 wrangler tank - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-07-2018, 07:20 AM   #1 (permalink)
rockbuggy84's Avatar
Member # 45202
Very simple question, I cannot find the answer to.
I need to know if a fuel pump from an 05-06 TJ will drop in a 97 TJ tank.
97-04 TJ fuel pressure was regulated at 49 psi +/- 2.
05-06 was regulated at 58 psi +/- 2.
My V8 swap requires 58 psi.
Novak sells a bulkhead to remove my factory regulator, but Iíd prefer using a factory pump thatís brand new, for less money.
"Whiskey is cheap, Talk cost money"
rockbuggy84 is offline   Reply With Quote Quick reply to this message
Old 11-07-2018, 08:49 AM   #2 (permalink)
Member # 178200
I am 99% sure what your asking will physically work. Only difference is the late model TJ/LJ fuel pump module is a returnless design. Regulator is built into pump module and there is no return line fitting on it.
Not sure how well that setup will work if your engine already has a regulator on the fuel rail and is a return to tank design.
SLOWPOKE693 is offline   Reply With Quote Quick reply to this message
Old 11-07-2018, 10:55 AM   #3 (permalink)
Member # 101521
I used my factory 2000 fuel pump without a problem with my LS swap. I just Capped the return line on my motor.
2000 TJ SE, 5.3l, 4l60E Atlas 5.1
rcherb is offline   Reply With Quote Quick reply to this message
