Line lock - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-03-2018, 09:12 AM   #1 (permalink)
zippyridgerunner's Avatar
Member # 9587
Line lock
I have a 1979 CJ-7. How much BS is it to connect it? I was thinking about this one. https://www.amazon.com/Evilenergy-Br...r+brakes&psc=1
I had a stroke so my writing is usually fucked
2006 LJ Rubicon 1979 CJ-7
zippyridgerunner is offline   Reply With Quote Quick reply to this message
Old 12-03-2018, 10:19 AM   #2 (permalink)
Member # 83301
meh, I am using a brass ball valve form mcmaster carr
'79 chevy k30 vortec 350/sm465/205/205/5.13's 40" NITTO trail grapplers on dirtylife beadlocks.
Old 12-03-2018, 04:26 PM   #3 (permalink)
GIJEEPN
DriverJC's Avatar
Member # 135100
Send a message via ICQ to DriverJC Send a message via Yahoo to DriverJC
Line Locks are great if you aren't comfortable running the hydraulic brake lines into the cab. However, from what I've read, they do tend to bleed down rather quickly.
My build will be using Turning brakes and a ball valve for e-brakes.
Joel.
DriverJC is offline   Reply With Quote Quick reply to this message
Old 12-04-2018, 07:31 PM   #4 (permalink)
Member # 9587
I have no clue what you are talking about? Describe please
Old 12-05-2018, 05:13 AM   #5 (permalink)
Member # 83301
PN# 4114T21
https://www.mcmaster.com/catalog/124/476
press the brakes, turn the valve, locks the brakes on that circuit. Plum it up under the dash.
Old 12-05-2018, 09:57 AM   #6 (permalink)
Member # 190921
I've been running an electric line lock for years. Never experienced a bleed down.... have had it set for long periods of time while rig was on an incline.
Don't remember the brand, bought it @ Summit Racing
{I swear you are such a fag it could be raining pussy and you'd still get hit with a dick.}
Underkill is offline   Reply With Quote Quick reply to this message
Old 12-06-2018, 04:26 PM   #7 (permalink)
Member # 202363
I have run an electric line lock for years as well. Never had any problems with bleed down. I always forget to turn it off after the Jeep sits for a while and then think its broken because it won't move.
zuzu is offline   Reply With Quote Quick reply to this message
Old 12-07-2018, 01:40 PM   #8 (permalink)
Member # 9587
I bought this one https://www.amazon.com/dp/B0734X5DLQ...e4x4convert-20.
I have a line going to my front brake and a line going to my back brakes. How can you run one line for all 4 wheels? If I had to run just one line what would be better front where all the weight is back where the traction is?
Thanks people!
Old 12-07-2018, 02:05 PM   #9 (permalink)
GIJEEPN
DriverJC's Avatar
Member # 135100
Thanks people!
If you want to lock all 4 wheels, you would need two of those. Install them between the master cylinder and the combo valve, then wire them to the same switch.
If you only want to buy one. I would lock the rear wheels. that's where the E-Brake is anyway.
Just my $.02 worth. And probably isn't worth that much.
Joel
Old 12-07-2018, 04:59 PM   #10 (permalink)
hurleygo3's Avatar
Member # 80862
I've had a badass Mico line lock. But I've switched to the Allstar ball valve like posted above. Cheap and just plain works.
Mike Johnson #43 7 time EMC KOH finisher, 6 top 5's
hurleygo3 is offline   Reply With Quote Quick reply to this message
Old 12-10-2018, 04:34 PM   #11 (permalink)
Member # 859684
Mico is more like a hydraulic parking brake. We have them on pretty much everything with a manual transmission and non airbrake. Flip the switch and apply the pedal, check valve holds the brake on (even with a power failure) and they have a pressure switch you are supposed to hook to the horn so if the brake bleeds (with power applied) off your horn honks as your truck gets ready to roll away.
A regular line lock will release if the power is cut, and isn't supposed to be used for parking. Mico is 10x the money of a line lock
Shorthood is offline   Reply With Quote Quick reply to this message
Old 12-28-2018, 02:35 PM   #12 (permalink)
Member # 63333
PN# 4114T21
Me too. Mine is a plumbing ball valve. The one on the rear has been on for 10 years or more. It is pretty easy to cut the line under the tub and run it in.
The one in front I did a few years ago. Same thing but you have to run it straight from the master and back to the proportioning valve.
I have never had a problem with it bleeding off.
Really the only problem I have had is forgetting when they are on. It would be nice to have a light to tell you when they are on. More work then I really want to do though.
Morton IL, 93 YJ
TSEJEEPERS is offline   Reply With Quote Quick reply to this message
