Tj Currie Rock Jock 60 Sway bar - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-05-2019, 04:39 PM   #1 (permalink)
Member # 152235
Does Anyone know of a Factory mounted sway bar that will work with the Rock jock 60 ? Other that a Anti Rock style . Thanks ahead of time .
dozer wright is offline   Reply With Quote Quick reply to this message
Old 02-05-2019, 04:44 PM   #2 (permalink)
Member # 196897
What is so special about a rock jock 60?
thedirtman is offline   Reply With Quote Quick reply to this message
Old 02-05-2019, 07:02 PM   #3 (permalink)
Member # 152235
The Rockjock 60 is High Pinion rear . With a diff cover set at a 45 degree angle and
A Very tall and Wide center Section . Allows extra ground clearance.
Old 02-06-2019, 07:41 AM   #4 (permalink)
caryt's Avatar
Member # 27775
caryt is offline   Reply With Quote Quick reply to this message
Old 02-07-2019, 04:26 AM   #5 (permalink)
Member # 192976
Ain't no way a stock sway bar is fitting a 60. You'll have to run an anti-rock or similar if you plan to run a sway bar in the rear.
04 TJ - Links, Stretched, Dana 44's, Full Hydro and 38 TSL's
Carolina Trail Blazers
Redneck92 is offline   Reply With Quote Quick reply to this message
Old 02-15-2019, 08:18 PM   #6 (permalink)
Member # 152235
A stock Sway bar does work upside down. I'm looking for one that will mount in the factory position. Probably just going to order a Anti rock to match the front.
Old 02-15-2019, 09:09 PM   #7 (permalink)
wildman4x4nut's Avatar
Member # 21893
Other than as you said running it upside down your only choice is to use a anti-rock style rear swaybar. I have a TeraLow CRD60 and have ran into the same issues.
TJ Builds:
I'm an ASSHAT!!!!!!!!!!
Scars are just to remind you of where you have been, Not where you're going.
wildman4x4nut is offline   Reply With Quote Quick reply to this message
Old 02-16-2019, 06:32 AM   #8 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
You can use the factory sway bar, I did. I used some 1/2" thick bar stock that I drilled and tapped to mount to the brackets on the RJ60. They extended about 2" above/back from the welded on bracket. I then mounted the stock sway bar to these. That moved the sway bar up & back enough to clear the pumpkin.
One of the great achievements of science has been, if not to make it impossible for intelligent people to be religious, then at least to make it possible for them not to be religious. We should not retreat from this accomplishment.
Salesmen and women. God sells to the ignorant.
SanDiegoCJ is offline   Reply With Quote Quick reply to this message
Old 02-18-2019, 03:26 PM   #9 (permalink)
Member # 152235
Thanks for the info guys greatly appreciated.
Similar Threads
Ultimate Wrangler Build Ups and Swaps thread gtxracer Jeep - Hardcore Tech 365 02-13-2020 03:00 PM
Currie/G2 Dana 60 Iron Rock Jock Rearend, w/ARB 5.13 gears Disc Brakes- L.A, CA Lajeep1976 Axles/Tires/Wheels For Sale 5 11-29-2014 08:36 PM
F/R Currie Rock Jock Dana 60s for Jeep TJ - Houston, TX Davetha Axles/Tires/Wheels For Sale 12 08-09-2013 07:27 AM
