78-79 Dana 60 or Super Duty Dana 60 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-07-2019, 06:55 AM   #1 (permalink)
-jb-'s Avatar
Member # 117969
Which would you prefer and why?
I have a 79 sitting at the house. I've had it for awhile. Buddy has a super 60 from a 05 and wants to trade plus cash on his end because my 79 Dana 60 will be easier to run his leaf springs on.
I have an LJ I'll be putting a 60 under either on coils or coilovers. So I could do either using an artec kit for the super 60 to mount coils if I went that way.
I'm open to reasons on both
Lets go wheelin!!!
-jb- is offline   Reply With Quote Quick reply to this message
Old 02-07-2019, 09:05 AM   #2 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
the 79 is light, has more clear axle tube to work with, and the kp outers are bolt on steering upgrades.
Down side is ford kp knuckles suck.
.the super60 is way bigger, stupid bolt pattern, steering changes are expensive.
But youre getting a very strong axle and $$$
Old 02-07-2019, 09:14 AM   #3 (permalink)
Member # 79509
What rear axle are you running? 05+ SD60 forces you to run 8x170. Yes you can redrill to 8x6.5, but its a moot point in the long run.
Tire size, driving style, etc also come into play. If youre going to run 37s. Id pimp out and drop coin on the 79 KP60. If you're going for brute size and 39s+, the SD60 would be hard to overlook.
My opinion is biased, i have two KP60s rat holed. I can buy an 05+ 60 any day for $500. Personally, a trade isnt worth it because the availability of SD60s will only increase.
Black Sheep is offline   Reply With Quote Quick reply to this message
Old 02-07-2019, 10:15 AM   #4 (permalink)
-jb-'s Avatar
Member # 117969
The rear axle doesn't matter. I have a Dana 70 rear to use with the 79. But it's not hard to pick up a 10.5 for pennies on the dollar at the local yard.
The lug pattern doesn't bother me. Cutting casting off to get more tube doesn't bother me. My TJ I am building has a 95 Balljoint 60 in it, I had to cut casting off to show more tube for link brackets.
I understand the strength differences and the KP needing stronger knuckles.
Which one packages better under a TJ with physical steering attached? (My TJ I'm running full hydro, but on the LJ build later on would like to keep it more street legal)
How is the caster on the Super 60? I know on the 79, the pinion has to point lower to get decent caster.
I know the super 60 is 2inches wider at 71wms. Any ill effects on that?
I'm ok with needing to upgrade parts if needed. I know the SD comes factory with 35spline. My goal is to run a 40in tire on an LJ as a weekend toy.
Trying to figure out if trading a 79 dana 60 and dana 70 for a SD 60 and cash is worth it or not. 79's are hard to come by but I've read the diff being 3inches more center makes for issues in packaging. I could slide the 79 under a Jeep at the house to figure this all out.
Lets go wheelin!!!
Old 02-07-2019, 10:22 AM   #5 (permalink)
Member # 192976
The 79 is worth more to most for some reason I still don't understand so depending on how much cash your buddy is offering I'd go that route and get the SD 60.
04 TJ - Links, Stretched, Dana 44's, Full Hydro and 38 TSL's
Carolina Trail Blazers
Redneck92 is offline   Reply With Quote Quick reply to this message
Old 02-07-2019, 09:36 PM   #6 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Id rat hole the 79 axle and buy a superduty axle. I agree with newbs post above.
I called a local wrecker and a superduty front was $540 it the door. I think most guys are on to these axles. I saw a 79 Dana 60 not sell at a swap meet for $800. Not a crazy good deal but cheap enough it should ha e sold. Most guys are doing super duty stuff now king pin shit will have to come down in price.
Old 02-07-2019, 10:13 PM   #7 (permalink)
Member # 53528
contradict yourself much?
https://patparts.com/products/sd60-m...ug-drill-plate
bolt pattern is not a big enough deal to really even mention, let alone the very first thing you do
Similar Threads
Machine shop and Broaching onetoncv The Job Shop 232 07-10-2019 01:10 PM
99-04 super duty dana 60 front axle questions Ezalycasaid Newbie General 4x4 Discussion 7 06-07-2018 09:37 PM
05+ Ford Super Duty Dana 60 Full Width Truss Kit TMR Customs Axles/Tires/Wheels 11 11-14-2017 08:42 AM
78 79 ford hp dana 60 arkansas mopartyson82 Axles/Tires/Wheels For Sale 2 07-10-2016 07:29 PM
Lifted 97 Jeep TJ Sport + 79 Dana 60 Front/04 Dana 60 Rear **SoCal** jeep fu Vehicles and Trailers For Sale 2 05-01-2016 04:36 PM
