Wich dana 30 should use - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-09-2019, 06:07 PM   #1 (permalink)
zukidude's Avatar
Member # 9442
I got a dana 44 with 373s to replace my 35 my Tj has 307s
I have acquired 2 dana 30 with 373s
1. Low pinion non disconnect already has all brackets easy to install
2. High pinion has disconnect I will eliminate it install seal, plate solid axel I have to weld on the coil pads shock mounts ext
Is high pinion worth the extra cost ($200) and time or just use the low pinion and call it good
I’m not going to wheel this jeep hard just want it to be a little tough and reliable
2000 TJ
zukidude is offline   Reply With Quote Quick reply to this message
Old 02-09-2019, 06:13 PM   #2 (permalink)
wildman4x4nut's Avatar
Member # 21893
You aren't going to wheel it hard then there isn't anything wrong with keeping the LP30. The main reason for going with a HP30 is to keep your driveshaft out of the rocks and for gear strength. What size tire are you planning on running?
Where did you find the D44? I've been looking for one for my daughters TJ but hate paying $1K or more for one. I can build a reliable D35 for that since she won't be going over 33" tires for a long time.
TJ Builds:
I'm an ASSHAT!!!!!!!!!!
Scars are just to remind you of where you have been, Not where you're going.
wildman4x4nut is offline   Reply With Quote Quick reply to this message
Old 02-09-2019, 06:24 PM   #3 (permalink)
zukidude's Avatar
Member # 9442
Got lucky found it in pasco paid $425 running 33s
2000 TJ
Old 02-09-2019, 06:54 PM   #4 (permalink)
Member # 21893
Dang that is a great price. I keep looking but just haven't scored one yet.
Good luck on the D30. As I said if you aren't building it for Funny Rocks type stuff the LP30 should be okay. I have a empty HP30 sitting here for when I decide to regear my daughters TJ.
Mine is built for rocks and other stuff while hers is a DD and won't see hard trails. Only reason why I would even think about keeping the D35.
TJ Builds:
Old 02-09-2019, 07:11 PM   #5 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
If you are running a d30, the only one worth running is a hp non disconnect. The rest suck. The LP sucks w/33s and a locker.
& Blaine
:tank:
Old 02-09-2019, 09:54 PM   #6 (permalink)
Member # 214685
Its a D30. They all suck.
The HP just being the least shitty.
Byro is offline   Reply With Quote Quick reply to this message
Old 02-09-2019, 10:11 PM   #7 (permalink)
Member # 79509
Correct
Also correct
3.73s is a waste of time and effort.
Black Sheep is offline   Reply With Quote Quick reply to this message
Old 02-10-2019, 09:53 AM   #8 (permalink)
Member # 21893
He isn't REGEARING to 3.73 he has axles with these in them already. Just asking which is the better of 2 D30's to run.
No work LP30
About $200 of work HP30
So which one to run?
TJ Builds:
Old 02-10-2019, 10:05 AM   #9 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
No work LP30
Id go hp and leave the 2pc axle. Screw a bolt in it to keep it engaged. Save the LP for when the hp breaks. I wouldnt spend a dime on either. I did that when I was young and dumb. Never again.
& Blaine
:tank:
Old 02-10-2019, 11:04 AM   #10 (permalink)
Member # 79509
No work LP30
Thats my point. I wouldnt waste time turning bolts on either. If youre going to swap axles, its a waste of time, money, and resources to put in 3.73s.
I’d go hp and leave the 2pc axle. Screw a bolt in it to keep it engaged. Save the LP for when the hp breaks. I wouldn’t spend a dime on either. I did that when I was young and dumb. Never again.
Exactly. Its not like these are the only choices OP has. Its a jeep, the options are indefinite. Arbitrarily speaking, hes spending $500 and wasting time, when he could spend $1000 and have a decent set up.
Old 02-10-2019, 06:19 PM   #11 (permalink)
Member # 21893
I get what you are saying but it sound like he already has the D30's laying around and just bought the D44. It also sounds like this isn't a serious trail rig so the 3.73 gears may not be GREAT but he has axles with the same ratio. It doesn't sound like he wants to regear the axles.
He is asking of his two choices with the D30 which one would be the better choice. From what he has stated I still think the LP30 is the better option.
TJ Builds:
Similar Threads
Wanted: Dana 30 Front Axles, Complete montezuma Wanted! 4 07-17-2015 03:20 PM
Jeep dana 30 (disconnect) and dana 35 rear bare housings F-150 Axles/Tires/Wheels For Sale 13 04-19-2015 06:53 PM
Dana 30 and 35 out of 05 TJ $500 YukonBlu Axles/Tires/Wheels For Sale 0 03-03-2012 01:08 PM
