Safe Way To Pull Dana 300 By Yourself? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-17-2019, 03:10 PM   #1 (permalink)
Member # 18016
Need to drop my Dana 300, without actually dropping it on myself or the concrete. Any advice on how to secure it to a floor jack, tranny jack, or other methods? Underneath a CJ-7, standard angled clocking. Looks a bit daunting while laying underneath. Looked at the trans jacks from Harbor Freight but doesn't look like it would be very helpful. Think the X-fer case is about 100 lbs.
Thanks.
~JM~ is offline   Reply With Quote Quick reply to this message
Old 02-17-2019, 03:27 PM   #2 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
Safest way is to use a transmission jack and a 1" ratchet strap.
One of the great achievements of science has been, if not to make it impossible for intelligent people to be religious, then at least to make it possible for them not to be religious. We should not retreat from this accomplishment.
Salesmen and women. God sells to the ignorant.
SanDiegoCJ is offline   Reply With Quote Quick reply to this message
Old 02-17-2019, 03:44 PM   #3 (permalink)
Member # 18016
Does the platform on the tranny jack tilt to match the angle of the X-fer case? I'm too old to muscle it out of there & back in any more. Thanks.
Old 02-17-2019, 04:21 PM   #4 (permalink)
Member # 119189
atv jack and some boards, its about 15" square on top, goes up about 18", use boards to either level the load or just pull it back onto the jack...done it too many times.
astjp2 is offline   Reply With Quote Quick reply to this message
Old 02-17-2019, 04:23 PM   #5 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
What San Diego said. Iíve also used an engine hoist through the tunnel. Another thing Iíve done is used ratchets straps around the frame to lift up the tcase. I use two and alternate them if that makes sense. Or just find someone younger. Theyíre only 90obs or so.
Old 02-17-2019, 04:40 PM   #6 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
300 are about 65lbs.
Not hard to man handle
Old 02-17-2019, 05:05 PM   #7 (permalink)
Member # 18016
Found conflicting reports on the weight. I recall carrying it once & there was weight, but it wasn't bad. That was well over 10 years ago though & I wasn't laying on my back.
Old 02-17-2019, 05:44 PM   #8 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
On your back makes it easier. Its like a straight bench press.
Jack under the trans and remover the skid,
Remove both drivelines and shifter
Remove 5 of the 6 face bolts leaving a lower easier one to get to.
Lay on back dirrectly under it.
Right hand on tcase offset, left hand pull remaining bolt.
Left hand on left side of tcase.
Wiggle tcase and slide towards back of jeep.
Lay on chest then slide to ground
Old 02-17-2019, 06:19 PM   #9 (permalink)
BDK
BDK's Avatar
Member # 295498
Lay on back dirrectly under it. Do not wear safety glasses
Right hand on tcase offset, left hand pull remaining bolt. Make sure you are alone and away from any means of communication before you do this step
Wiggle tcase and slide towards back of jeep. Tcase slips off hands, slams into chest and crushes sternum
Lay on chest then slide to groundSlowly roll out under rig while gasping last breath
I fixed it for you
In politics, stupidity is not a handicap.-- Napoleon Bonaparte
BDK is offline   Reply With Quote Quick reply to this message
Old 02-17-2019, 06:23 PM   #10 (permalink)
Member # 79509
Safest way is a helping hand.
Otherwise, its not hard to bench press 85lbs.
Black Sheep is offline   Reply With Quote Quick reply to this message
Old 02-17-2019, 06:38 PM   #11 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Well. If weve done nothing else, weve identified 2 pbb members with rubberbands for arms.
Old 02-17-2019, 07:13 PM   #12 (permalink)
Member # 18016
That's how it would have been handled several years ago.
Work smarter, not harder. It's an age thing.
Old 02-17-2019, 07:20 PM   #13 (permalink)
redsand723's Avatar
Member # 222933
Location: southern illinois (no where near that shit hole chicago)
Bench press it in and out
Sent from my SM-N950U using Tapatalk
Sent via smoke signal
redsand723 is offline   Reply With Quote Quick reply to this message
Old 02-17-2019, 08:11 PM   #14 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Jm, can you lift and load the tires on your jeep into a pickup bed?
Old 02-17-2019, 08:14 PM   #15 (permalink)
Member # 53528
https://www.summitracing.com/parts/wmr-w41044
https://www.ebay.com/i/282991315646?chn=ps
https://www.ebay.com/i/252968540056?rt=nc
Old 02-18-2019, 03:29 AM   #16 (permalink)
Member # 85771
Its a tcase, not a motor. Bench press it in.
I find it easier the lower it is. Take all the air out of the tires and use a floor jack.
Make Forums Great Again!
Old 02-18-2019, 06:35 PM   #17 (permalink)
Member # 119189
I have still used the ATV jack to get it close and then I can man handle it it...
Old 02-18-2019, 06:51 PM   #18 (permalink)
Member # 56430
85 pounds, plus a little.
TTC 1994, TTCC 2012, Trail Tours '05-'10, '12-'13
Member Eldorado Dust Devils, a PNW4WDA member
Treeclimber is offline   Reply With Quote Quick reply to this message
Old 02-18-2019, 08:02 PM   #19 (permalink)
YotaAtieToo's Avatar
Member # 25632
Wtf? A D300? Really? A 203/205 I could understand, but for fucks sakes, you can't pull a ~70 lb tcase by yourself?
And my buddies made fun of me for getting a transmission jack to change the clutch in my F350
Old 02-19-2019, 02:52 AM   #20 (permalink)
Newbie
Member # 688362
I benched my 300 in and out about a dozen times in my recent CJ5 build and I weigh a buck 60. All you have to to do is get the input over the trans output and then rotate it into position to start a bolt...
M390 is offline   Reply With Quote Quick reply to this message
Old 02-20-2019, 12:57 AM   #21 (permalink)
Member # 53528
whats so difficult for you tards to grasp that hes OLD as in elderly, would you tell your 70yr old grandpa that just had a hip replacement to just bench press it in there?
did i mention hes old? he mentioned it, more than once
Old 02-20-2019, 09:08 AM   #22 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
He said age not old.
Fuck you for assuming old men are pussies
Old 02-20-2019, 09:49 AM   #23 (permalink)
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
Mine would've given me shit for *not* doing it that way, then proceed to show me how it's done. I probably would have had to help him up from the floor though.
The Alternative Rocker - Taurus SHO V6-powered, Explorer-framed, TTB-front, RCV'd, YJ-bodied east coast racer
Flying Pig Racing #512
vetteboy79 is offline   Reply With Quote Quick reply to this message
Old 02-20-2019, 10:49 AM   #24 (permalink)
Member # 556914
Take the top off. Run the winch over the rafters and down in the trans cover. The take the remote under the jeep and ease it up or down.
limited is offline   Reply With Quote Quick reply to this message
Old 02-20-2019, 11:33 AM   #25 (permalink)
Member # 10365
This discussion reminds me of the time I was pulling my Atlas and it was resisting a bit...I yanked a little harder/gave it a little shake (none of this is a euphemism )and it came off in a HURRY. Inertia took it a little past vertical on my outstretched arms and it started arcing down towards my face! Still couldn't tell you exactly how, but I managed to get the ~115lb ballistic missile under control a few inches before impact.
The experience didn't stop me from doing this by hand, but I can certainly understand why someone who has a few more years under their belt might choose to use a tranny jack or similar to remove/install even the d300. Hell, he might not even be weaker, just smarter!
"Not as Limited" tube chassis CJ build:
CJay is offline   Reply With Quote Quick reply to this message
Similar Threads
It's sale time! Gears, Lockers, Install kits!! CCOR Axles/Tires/Wheels 4579 06-27-2019 05:41 AM
Will You Buy USA Made R&P / Stub Shafts cperry Axles/Tires/Wheels 13 09-26-2016 06:21 AM
Dana 300, dana 400/14 bolt toyota adapters, aw4 to dana 300 clocking ring Scubasteve83 Engines/Trannys/T-Cases For Sale 14 07-02-2016 06:37 PM
Garage Clean Out, Driveshaft, Dana 300, Dana 60 stuff, random stuff, cheap CJ2ota Misc. Stuff For Sale 4 04-16-2016 07:01 AM
