shock towers - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-18-2019, 06:40 PM   #1 (permalink)
Member # 119189
shock towers
Ok, I am going to outboard my shocks on the rear of my LJ, I am going to use the barnes towers, what length should I get, they have a 15.25 and a 17.75, It will be a 4" suspension lift and 12" stroke shocks...
astjp2 is offline   Reply With Quote Quick reply to this message
Old 02-18-2019, 06:43 PM   #2 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
What is the compressed length of the shock you want to use?
& Blaine
:tank:
Old 02-18-2019, 08:14 PM   #3 (permalink)
Member # 709969
Unless you have a very odd shock either will require that you shorten them.
the1mavin is offline   Reply With Quote Quick reply to this message
Old 02-18-2019, 08:37 PM   #4 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
FWIW, Iran fox 12 inch coil overs on my synergy shock brackets. They eventually made a taller bracket for 14s. Everybody seems to copy their brackets. 14s are tall, 12s are short. But if you run a conventional shock you may need an even shorter bracket.
& Blaine
:tank:
Old 02-18-2019, 10:15 PM   #5 (permalink)
Member # 119189
I planned on shortening them, I just didnt want to get too short. 19.10 collapsed. Tim
Old 02-18-2019, 11:26 PM   #6 (permalink)
wildman4x4nut's Avatar
Member # 21893
I'm 90% sure my Walker Evans are 12" shocks and here is the original Poly shock towers. I got one of their first sets they sold in 2005. You can see how much I had to cut off.
TJ Builds:
I'm an ASSHAT!!!!!!!!!!
Scars are just to remind you of where you have been, Not where you're going.
wildman4x4nut is offline   Reply With Quote Quick reply to this message
Old 02-19-2019, 05:18 AM   #7 (permalink)
Member # 192976
Definitely buy the shorter ones. I fairly certain the ones I made were just over ~12"
04 TJ - Links, Stretched, Dana 44's, Full Hydro and 38 TSL's
Carolina Trail Blazers
Redneck92 is offline   Reply With Quote Quick reply to this message
Old 02-22-2019, 07:35 AM   #8 (permalink)
gregj50's Avatar
Member # 151818
What is that?? Air bag looking thing???
Looks like itís on the spring brackets???
gregj50 is offline   Reply With Quote Quick reply to this message
Old 02-22-2019, 08:54 AM   #9 (permalink)
Member # 21893
It is a air bag suspension system made by Off-Road Only called the AiRock. They started out making them for the TJ and now make them for the JK & JL. It replaces your coil springs with air bags in either a 4" or 6" lift. It is computer controlled so it self levels when driving so if you have a trailer hooked up or a heavy load in the rear. It has an on road set height and then an off road height. When doing side hills you can roll the body of the Jeep to the uphill side. Or when climbing hills or going down ledges you can raise or lower the front or rear.
It isn't for everyone and isn't as flexy as coil overs but for me it works.
TJ Builds:
Similar Threads
Ford RBV 83-96 Custom Long Travel Reservoir Shock Coil Towers arrabil Misc. Stuff For Sale 0 09-12-2018 11:33 AM
Synergy Mfg. Front Dodge Shock Towers Wubsor Misc. Stuff For Sale 0 04-03-2017 08:28 AM
Motobilt Shock Towers for 2.0 shocks MotoBilt Suspension 6 03-27-2017 12:29 PM
Ruffstuff Shock Towers! Gravel Maker Suspension 79 12-12-2016 09:10 AM
