What did I just break - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-20-2019, 04:56 AM   #1 (permalink)
Newbie
BronsonJeep's Avatar
Member # 775225
After doing some work on the Jeep and getting the brakes, traction bar, and air lines dialed in I took her for a test drive.
I was pretty happy with the results and indulged myself in a small celebratory burnout.
After the burnout I have gear noise on coast or deceleration.
Yj, rear SOA, Super 88, 5.13 gears, 37" tires.
I've seen articles pointing to pinion bearing preload, others citing carrier bearing issues.
I've never set up the innards of a differential before - What should I look for here? Hopefully someone has done this same boneheaded move and has experience fixing it....
89YJ; Front 3-link stretch Waggy 44; Rear SOA Super 88; 5.7 V8/3550/231HD; 5.13's; 37s, cage, hydro, *might* have just bought a set of tons
BronsonJeep is offline   Reply With Quote Quick reply to this message
Old 03-20-2019, 05:33 AM   #2 (permalink)
Member # 85771
Open the diff and have a look.
Make Forums Great Again!
Old 03-20-2019, 12:00 PM   #3 (permalink)
Member # 548137
any play in the pinion?
denverd1 is offline   Reply With Quote Quick reply to this message
Old 03-21-2019, 06:50 PM   #4 (permalink)
Newbie
Member # 775225
Nothing noticeable from working the driveshaft by hand....
I'm going to pull the diff apart, check pinion bearing preload, and give everything a good visual once over. Just waiting on a dial in/lbs torque wrench to arrive in the mail.
Anything else I should check out while I'm in there?
Old 03-31-2019, 06:32 AM   #5 (permalink)
Newbie
Member # 775225
So I disconnected the driveshaft and torqued the pinion nut, put shaft back in and went for a test drive. Much better. Still some noise at highway speed so I'm going to add a little more to the nut.
Old 03-31-2019, 08:19 AM   #6 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
Pull the cover and look. If it was pinion preload, there would have been play in the pinion.
& Blaine
:tank:
Old 03-31-2019, 03:43 PM   #7 (permalink)
Member # 685402
The 8.8 uses a crush sleeve on the pinion unless whoever did your gears did a crush sleeve eliminator. Be careful not to crush the sleeve any more if it’s still using the crush sleeve.
Weezul is offline   Reply With Quote Quick reply to this message
Old 03-31-2019, 04:12 PM   #8 (permalink)
Roo skin seat covers
3nuts's Avatar
Member # 342298
Sorry. But that shits too funny
If we had bacon, we could have bacon and eggs, if we had eggs.
3nuts is offline   Reply With Quote Quick reply to this message
Old 04-03-2019, 04:40 AM   #9 (permalink)
Newbie
Member # 775225
There was still noise at higher speeds, and around 65mph a new vibration set in.
Finally got off my ass and pulled the arb and ring gear out, noticed some scoring on the teeth. Pinion had play, bearings were shot. I replaced the R&P and bearings, had a local shop set them up.
No More Burnouts!
(until I link the rear.....)
Old 04-03-2019, 04:44 AM   #10 (permalink)
Newbie
Member # 775225
Yessir, there sure was.
Originally Posted by Weezul View Post
The 8.8 uses a crush sleeve on the pinion unless whoever did your gears did a crush sleeve eliminator. Be careful not to crush the sleeve any more if itís still using the crush sleeve.
So I did the thing you said not to do, leading to more damage and replaced guts.
Should call this thread "How to perform a $700 burnout" lol.
Learning experience I guess.
Old 04-03-2019, 07:18 AM   #11 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
No More Burnouts!
Linking the rear wonít make your differential stronger. You will break it just the same with a linked rear end as a traction bar. Upgrade your shit!
& Blaine
:tank:
Old 04-03-2019, 07:24 AM   #12 (permalink)
Member # 143737
Should have just done tons
POS Ranger on narrow 3/4 tons with a 357w noise maker
posford is offline   Reply With Quote Quick reply to this message
Old 04-03-2019, 08:06 AM   #13 (permalink)
Newbie
Member # 775225
My thinking is that it was the earth shaking axle hop that caused the issue.
An 8.8 with chromoly shafts is plenty strong to roast 37" rubber without all the up and down movement.
Either way there are a set of 60's getting crated and sent my way as I type this so my shit is for sure about to get upgraded....
I have a set on the way and TBH I'm gonna miss the narrower stance once they're in. If I have the $$ I'd order up a set of 65" wms somethings from one of the manufacturers but I don't.
I may shorten my ford kp60 and matching rear 60 in the future if the full width look really rubs me the wrong way.
Old 04-03-2019, 08:12 AM   #14 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
If the axle hopped, your traction bar geometry is not good.
& Blaine
:tank:
Old 04-03-2019, 08:22 AM   #15 (permalink)
Member # 143737
Chevy cab and chassis 14 bolt is 65" I think, fronts stupid easy to narrow
Old 04-03-2019, 08:27 AM   #16 (permalink)
Tipped's Avatar
Member # 304297
63"
Tipped is offline   Reply With Quote Quick reply to this message
Old 04-07-2019, 06:53 PM   #17 (permalink)
Newbie
Member # 775225
it's basically an off-the-shelf unit from M.O.R.E.
the trac bar is there to limit wrap... how does it limit axle hop??
Old 04-07-2019, 10:57 PM   #18 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
Length, angle, etc. similar to how a 4 link does the same.
& Blaine
:tank:
Old 04-08-2019, 04:12 AM   #19 (permalink)
Newbie
Member # 775225
You may be right and you probably know a lot more about this than I do.
It seems to me that there is WAAAY more purposeful geometry going on in a four link, designed to provide control of any and all axle movement, than in a trac bar for SOA. These things are advertised to control axle wrap, period.
I think with the right combo of soft springs SOA, 37x15" tires at ~20psi, horsepower, pavement traction, locked rearend, 97" wheelbase, and a boneheaded drop clutch launch from 3mph, I can induce axle hop even with a well setup traction bar.
Sort of the same vibe as the tagline in your sig...
Old 04-10-2019, 09:19 PM   #20 (permalink)
Member # 31211
Originally Posted by Tipped View Post
63"
The mid 90s 3/4 ton suburban had a 65" WMS full float 8 lug 14 bolt. I have one in my heep.
charlieboyd65 is offline   Reply With Quote Quick reply to this message
Old 04-10-2019, 09:21 PM   #21 (permalink)
Member # 31211
Linked suspensions CAN control that if set up properly. If setup incorrectly, it can create a lot of unwanted issues. Make sure you do your homework.
Old 04-11-2019, 12:54 PM   #22 (permalink)
Tipped's Avatar
Member # 304297
63"
That’s great. Cab and chassis 14 bolts are 63” wms to wms. Srw 14 bolts like yours can be narrowed to 63” with c/c hubs. Look it up.
Old 04-11-2019, 03:02 PM   #23 (permalink)
Newbie
Member # 775225
That's a good find - 65" front and rear would suit me nicely but I've already got a set of 60's and I'm going to just un them as-is. 69" wide front, 67" wide rear.
The guys that would be setting up the geometry for me know what they're doing. They've built and raced buggies and are all running killer rigs. They did my front 3-link and I couldn't be happier with the street and trail manners. I like working on my own shit but I also know when to pull the experts in...
Similar Threads
Imminent dam break about 85 miles northeast of the Reno-Lake Tahoe area. bsdboy General Chit-Chat 20 02-21-2017 08:45 PM
Lost my exhaust break 85 K5 Blazer Build Dodge 5 03-24-2016 12:42 PM
New Barrel Break In Lil Uzi Outdoor Sports and Recreation 12 02-27-2016 08:37 AM
Claasic Bronco 44 Front Break in with Locker Overkill302YJ Ford 2 01-27-2016 05:11 PM
