Jeep 5.9L and AW4? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-21-2019, 06:47 AM   #1 (permalink)
Member # 85771
Jeep 5.9L and AW4?
An AX15 will bolt to a 5.9L, will a AW4?
I ended up with a lower mile 5.9L ZJ thatís got some body/rust issues and possible overdrive going out for $200. From what I have read, the tranny behind it is only going to work in that Jeep.
I had a thought of pulling the engine, scrapping the rest, and putting a AW4 behind it in my buggy. From my readings this hasnít been done but I canít figure out why.
Make Forums Great Again!
ky scrambled is online now   Reply With Quote Quick reply to this message
Old 03-21-2019, 08:33 AM   #2 (permalink)
wildman4x4nut's Avatar
Member # 21893
I don't think a AW4 will bolt up to a 5.9. The auto in the ZJ is a 46RE which is the same engine used in that era Dodge truck behind the 1500/2500 with a gas engine. When doing a engine swap into a TJ or YJ you have to use a Dakota NV3500 bellhousing to be able to use the AX-15. So since of that my guess is a AW4 won't work.
TJ Builds:
I'm an ASSHAT!!!!!!!!!!
Scars are just to remind you of where you have been, Not where you're going.
wildman4x4nut is offline   Reply With Quote Quick reply to this message
Old 03-21-2019, 08:36 AM   #3 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
You can bolt an AX15 to a 4.0
You can bolt an AW4 to a 4.0
You can bolt a AX15 to a 5.9
Why can’t you bolt an AW4 to a 5.9?
Edit: Apparently The AX15 uses different bell housings so this won’t work.
& Blaine
:tank:
Old 03-21-2019, 08:44 AM   #4 (permalink)
Member # 85771
The YJ came with an AX15, there is no bellhousing switch?
Why canít you bolt an AW4 to a 5.9?
That's my thought. Just didn't know what issues come into play with the flexplate.
Old 03-21-2019, 09:17 AM   #5 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
Yeah you may have to monkey with it a little.
& Blaine
:tank:
Old 03-21-2019, 09:21 AM   #6 (permalink)
Member # 214685
My thoughts exactly.
The only issue I could foresee is the flex plate/TC. Iím sure Novak or AA has something if a mixture of OEM parts will not work.
Also does the 5.9 use a bellhousing mounted CPS? That could be another issue.
Byro is offline   Reply With Quote Quick reply to this message
Old 03-21-2019, 10:30 AM   #7 (permalink)
Member # 85771
Flexplates below
4.0
Ring Gear Tooth Quantity: 164-tooth
Engine Balance: Internal
Flexplate Material: Steel
Notes: 13.81 in. outside diameter, 12 pitch.
5.9
Engine Balance: External
Notes: 11.5 in. outside diameter.
Looks like the 5.9 has a CPS in a very similar location to the 4.0.
Old 03-21-2019, 10:36 AM   #8 (permalink)
Member # 214685
The biggest thing is going to be the indexing of the pick up between the two.
If you could get away with the AW4 flex TC and starter that would make life pretty easy.
Old 03-21-2019, 10:57 AM   #9 (permalink)
Member # 85771
The distance between the end of the sensor and the gaps in the flexplate you mean?
Old 03-22-2019, 06:49 AM   #10 (permalink)
Member # 21893
You have to change the bellhousing on the AX-15 to be able to bolt it to a 5.9.
94-99 Dodge 3.9 V6 Bellhousing (Bolts up to the V8 and AX15 or Nv3550)
This is from one of the Dodge V-8 swap threads on JF
https://www.pirate4x4.com/forum/jeep...-question.html
https://www.novak-adapt.com/catalog/...-bellhousings/
You have to get the bellhousing from a Dodge Dakota. The 4.0 bellhousing WON'T bolt up.
https://www.jeepforum.com/forum/f12/...using-1292403/
https://nc4x4.com/forum/threads/5-2-...pattern.11438/
TJ Builds:
Old 03-22-2019, 08:33 AM   #11 (permalink)
Member # 85771
Thank you for killing my dreams!
I do appreciate the information
Old 03-24-2019, 07:32 PM   #12 (permalink)
Member # 21893
Sorry just trying to save you some time. It was a good idea. Why not get an adapter plate made like they use to do to make a Jeep T400 bolt up to a Chevy T400?
Does the bellhousing bolt to the AW4 or is it part of the housing?
TJ Builds:
Old 03-24-2019, 07:40 PM   #13 (permalink)
Member # 214685
One piece case.
Old 03-24-2019, 07:45 PM   #14 (permalink)
Member # 21893
That is what I thought but it has been a long time since I looked at one.
Adapter plate? But most likely not worth it.
TJ Builds:
Old 03-25-2019, 11:15 AM   #15 (permalink)
Member # 191442
AW-4 won't fit the Mopar Magnum small block, it does have a removable bellhousing, though. I don't think it would last behind the Magnum, anyways.
The Jeep 46RE is more compact than the Dodge 46RE, starter tucks in low and to the passenger side vs. sticking out to the drivers side. A lot better clearance for a front driver's side driveline, especially if you aren't running much lift. Also will clear a passenger side driveline, as the starter is really tucked in.
The 46RE is easy to rebuild and easy to build to hold ALOT of power. Many of the 47 and 48 RE parts and extra clutches can be installed in the 46RE. The Trans-go TFOD-2 shift kit works really well in them and cures most of the issues that the stock trans had.
The CPS bolts to the block on the Magnum engine, high and to the passenger side of center. The trans only has to be notched to clear it.
Marty, SoCal is offline   Reply With Quote Quick reply to this message
Similar Threads
Jeep 4.0 w/ harness and ecu / AW4 w/radesigns baja III Jmill1082 Engines/Trannys/T-Cases For Sale 10 12-13-2017 09:22 PM
Mira's '93 XJ 2-dr. build (11-year-old's first Jeep) 1x1_Speed_Craig Jeep - Cherokee 115 05-24-2015 06:29 PM
89 Jeep YJ, 4.0, AW4, 8.8, CedarGrove Vehicles and Trailers For Sale 2 05-11-2013 05:13 PM
