Transmission Issues - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-29-2019, 09:47 AM   #1 (permalink)
Slangy's Avatar
Member # 123044
Transmission Issues
Quick back story, I have a 97 Tj that I swapped in a 5.2L and 44RE out of a 99 Dodge Durango a few years back. The transmission now feels like I am in 3rd gear when I start out, sometimes it shifts and sometimes it doesn't. I will be driving down the road and all is well when I notice the engine reving because the damn transmission kicked out of gear.
So took it to the shop knowing it is probably toast. I got a quote for $2,800 to replace it . So I am off to pick it up from the shop and take it home to hopefully find a used one to swap into it before I leave for EJS. I guess what I am asking is this, would you buy a used one from a junk yard or what route would you take? I am just looking for some ideas to decide the best route to take.
Thanks in advance
Slangy is offline   Reply With Quote Quick reply to this message
Old 03-31-2019, 01:09 AM   #2 (permalink)
wildman4x4nut's Avatar
Member # 21893
How soon do you need a transmission? How much do you want to spend?
I had the same setup in my 97 TJ. A 44RE can be built VERY strong using some 46RE parts. Or you can just put a 46RE in it. You can get a rebuilt one off Ebay.
https://www.ebay.com/itm/A500-42RE-4...UAAOSwM4xXYvzV
Or a used one with 192,000 miles on it.
https://www.ebay.com/itm/1999-DODGE-...wAAOSw6qpahQsL
If you have the funds and the time I would go rebuilt. If you have the funds and time I would get a rebuilt performance transmission. I had Martin Saine
MSaine Performance
951-907-0434
build me a 46RE that can handle 600HP as I am building a 5.9 stroked to 6.7 for my TJ right now. Can't wait to try this thing out.
He is a Dodge transmission expert and builds a lot of transmissions for the Dakota guys who are drag racing their trucks. He can do either the 44RE or a 46RE.
TJ Builds:
I'm an ASSHAT!!!!!!!!!!
Scars are just to remind you of where you have been, Not where you're going.
wildman4x4nut is offline   Reply With Quote Quick reply to this message
Old 03-31-2019, 10:57 AM   #3 (permalink)
Member # 191442
In limp mode that trans will start out in second gear.
Have you checked for codes?
Might be something as simple as a bad governor pressure solenoid or pressure sensor (Pretty common). A relatively easy fix not much harder than changing the fluid and filter. Adjusting the bands is often neglected and should be done every 30k.
Check this site:
https://troubleshootmyvehicle.com/ch...-an-overhaul-2
If hardened seals are causing the intermittent slip (You will have gear ratio error codes). Use of a chemical trans additive often will cure it. KW Trans-X or Motor Purr "Tune Up" work really well.
Marty, SoCal is offline   Reply With Quote Quick reply to this message
Similar Threads
Check Valve in Transmission Cooler Lines? giles45shop General 4x4 Discussion 2 08-29-2018 04:48 AM
2017 Ram 2500 Transmission Issues? inthefield Tow Rigs and Trailers 5 08-14-2018 06:46 AM
Can you swap a 1999 AW4 transmission into a 1996 ? xj1 Jeep - Cherokee 0 09-11-2015 10:48 PM
why is my tranny overheating?! Kodiak 4x4 Chevy 30 09-19-2013 08:13 PM
