LS Swap eating power steering boxes and pumps. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-03-2019, 11:52 AM   #1 (permalink)
Member # 212988
So I have an LS swapped YJ converted the lines to AN fitting and using Russell -6 hose. Steering works great for a week or two then I start developing dead spots in the steering intermittently. Running 37" tires on a 79d60 when its working well I have no trouble turning the wheel and it doesnt seem to be straining. I plan on doing hydro assist but Im not sure thats going to be the fix for this issue. Are the lines to small? Do dead spots mean a pump issue or box issue? I have a trip and two weeks and I dont want to lose steering during the trip. Thanks
HankScorpi0 is online now   Reply With Quote Quick reply to this message
Old 04-03-2019, 12:51 PM   #2 (permalink)
slobrorunner's Avatar
Member # 186755
Are you using the stock LS pump and resi?
If not, what is your resi situation?
95 Barbie Jeep
slobrorunner is offline   Reply With Quote Quick reply to this message
Old 04-03-2019, 01:12 PM   #3 (permalink)
Member # 212988
Yes stock pump and reservoir 04 Silverado 1500
Old 04-04-2019, 08:35 AM   #4 (permalink)
GFY Racing's Avatar
Member # 136091
Location: Back in the good 'ol U S of A after three long deployements!
No clue on solutions, but some question (I'm assuming you've already been over, but doesn't hurt to double check).
1. Are you running a cooler?
2. Do you have any hard 90 degree angles? I believe these are known to cause cavitation since the flow is disrupted.
3. Have you flushed the entire steering system? I'm guessing there is debris in the system after the failure. Could cause early failure after installing new parts.
4. What size pulley are you running?
5. What type of fluid are you running?
Fighting for the right for SORRY PIECES OF SHIT to protest at soldier's funerals.
1989 XJ on 35s Work in Progress
GFY Racing is offline   Reply With Quote Quick reply to this message
Old 04-04-2019, 10:27 AM   #5 (permalink)
NERD
gtxracer's Avatar
Member # 25303
Yes, these are things we'll need to know to really diagnose the system.
Are you wheeling when these failures occur or street driving? Has the box been flushed? Are you sure the steering box isn't failing and throwing metal shards or seal material into the pump? I had a box that was eating seals and would find them in the lines as long as I didn't try to drive the Jeep after failure.
When the failure happens, does the steering get tight or do you lose only one direction? Is the pump hot when this happens? How does the fluid look? What's in the fluid as far as particles or seal material?
97 TJ Build:
2013 Raptor SuperCrew Tow Rig
Porsche
Fab Parts:
PNW Shock Tuning:
gtxracer is offline   Reply With Quote Quick reply to this message
Old 04-22-2019, 01:28 PM   #6 (permalink)
Member # 191442
Make sure you are using at least AC-Delco OEM fluid. At my work we were having all sorts of failures on 90's model GM's and Dodges with Saginaw steering and hydro-boost, and we cured them by using the Delco part # 10-5073 oem spec fluid.
The relief pistons were sticking in the bores of the pumps, reman and new Mopar/GM. All new lines, boosters and gearbox and added on filters and we were still having problems with the pressure relief sticking until we changed the fluid brand. We were using Johnsen's P.S. fluid.
Marty, SoCal is offline   Reply With Quote Quick reply to this message
Similar Threads
The 4500 steering that won a national points Championship jr4x General 4x4 Discussion 404 08-13-2019 11:13 AM
mah deuce JESSE_at_TLT Expedition Vehicles 1409 01-28-2019 10:09 PM
No power steering with hubs locked? Jerpies Jeep - Non Hardcore 9 10-02-2016 12:13 PM
Power Steering help - mixed components Drayke General 4x4 Discussion 3 02-01-2013 07:10 PM
