Dana 44 in my YJ - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-17-2019, 09:39 AM   #26 (permalink)
Member # 85771
Love to see a clean YJ. How does it drive?
Make Forums Great Again!
Old 09-17-2019, 10:32 AM   #27 (permalink)
paulhead's Avatar
Member # 41976
Felt good, with a little fine tuning should be a lot tighter. Curious how the 3 spd is gonna do on the hwy with the 4.88s and 37s. Probably gonna flat tow it til I get a trailer.
paulhead is offline   Reply With Quote Quick reply to this message
Old 09-17-2019, 10:37 AM   #28 (permalink)
Member # 85771
Let us know. I bought my Wife a turd 1993 YJ recently, 4.0 and automatic. The plan is 37s with 4.88s also.
Old 09-17-2019, 01:07 PM   #29 (permalink)
Member # 55560
Looks awesome. I have 4.56s with 35s and the AX15 and I want to convert to Auto so I'm curious how yours does as well.
A bunch of old crap
Mattafact is offline   Reply With Quote Quick reply to this message
Old 09-17-2019, 01:09 PM   #30 (permalink)
paulhead's Avatar
Member # 41976
I wouldn't do the 3 spd, I'd look into an AW4 with the OD. I ran 35's with 410s with this 3 spd and OD was wanting.
Old 09-17-2019, 01:12 PM   #31 (permalink)
Member # 55560
The AW4 is going to need something like the RAD shifter, right?
A bunch of old crap
Old 09-17-2019, 01:16 PM   #32 (permalink)
paulhead's Avatar
Member # 41976
Not sure. I found this https://www.stu-offroad.com/engine/a...awshift2-2.htm
Old 09-18-2019, 05:34 AM   #33 (permalink)
dzrtrataz's Avatar
Member # 25631
Send a message via AIM to dzrtrataz
You can use the RAD shifter, If your YJ is fuel injected. You should be able to wire in the AW4 computer into your wiring harness. I did this on mine. I have the MPI kit on my YJ, since is was carbed when I got it. Also mine was stick prior to adding the AW4. I used STU's site for reference when I did mine. You will need to get the pin diagram for your computer, to let you know what wires to tap into. I'm not using the RAD shift with mine, I have one just need to wiring it in one day.
dzrtrataz is offline   Reply With Quote Quick reply to this message
Old 10-04-2019, 01:08 PM   #34 (permalink)
paulhead's Avatar
Member # 41976
So I'm hitting like 3K at 58 MPH, speedometer isn't dead on but yeah, wish I had that OD.
Old 10-04-2019, 01:08 PM   #35 (permalink)
paulhead's Avatar
Member # 41976
After losing my mind with copper washers I got these aluminum ones that have a rubber seal on the inside part of the ring. Finally got the banjo bolts to stop leaking. The brake line fittings had a flat smooth surface as opposed to a grooved surface that seemed to prevent a seal from occurring.
https://www.summitracing.com/parts/ear-178007erl/
Old 10-04-2019, 01:14 PM   #36 (permalink)
paulhead's Avatar
Member # 41976
Found a piece of concrete, flexed a little, took some measurements for shocks. I flipped the tie rod under my knuckle using Ruffstuffs inserts, looks good. Drag link barely clears at full stuff.
Old 10-04-2019, 01:15 PM   #37 (permalink)
paulhead's Avatar
Member # 41976
Turns out I overlooked the pinion angle with the new springs and I'm gonna have to move it, it's like 10* off.
