Weird Dana 30 shafts - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-03-2019, 06:14 AM   #1 (permalink)
Member # 85771
Just bought a basket case 1993 YJ over the weekend for my wife. Havent really had a chance to tear into it much as there are 2 in line in front of it . I did notice that the front inner axle shafts seem splined on the yoke end. I have seen that on high end axles, bet never a Dana 30.
Itís got the CAD, the vacuum lines are cut, the front axle engages. Iím assuming itís got upgraded 1 pieces shafts in the front, just curious what they are/if anyone has seen them?
Make Forums Great Again!
Old 09-03-2019, 05:29 PM   #2 (permalink)
Member # 16505
Send a message via AIM to 92 Green YJ Send a message via Yahoo to 92 Green YJ
Pics? I am kind of intrigued.
92 Jeep Wrangler.
lots of mods with lots more to come. Just Empty Every Pocket!
92 Green YJ is offline   Reply With Quote Quick reply to this message
Old 09-03-2019, 07:29 PM   #3 (permalink)
Member # 178200
Was that done on the stock shafts to hold the plastic washers in place that protected the end of the tubes?
SLOWPOKE693 is offline   Reply With Quote Quick reply to this message
Old 09-03-2019, 08:23 PM   #4 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Not that ive seen.
If the cad was in the locked position when the lines were cut it stays that way.
Old 09-04-2019, 03:57 AM   #5 (permalink)
Member # 85771
right!
The plastic washer that keeps debris out of the tube?
I did not know that. Makes sense though as its a bit jerky full lock in 2wd. I just chocked that up to "its a jeep thing" and the jerking was the frame collapsing
I really want to leave this thing alone till I have time but I may have to pull a shaft and see.
Old 09-04-2019, 06:05 AM   #6 (permalink)
Member # 178200
Yes, that plastic washer
Old 09-04-2019, 09:27 AM   #7 (permalink)
GFY Racing's Avatar
Member # 136091
Location: Back in the good 'ol U S of A after three long deployements!
I had a set like that previously. I have no idea what year they're from, but they were 1 piece shafts, so I think they would have been 95+
Aside from that I don't have any more details for you. I never ran them. Ended up giving them away when I tore out the D30.
Fighting for the right for SORRY PIECES OF SHIT to protest at soldier's funerals.
1989 XJ on 35s Work in Progress
GFY Racing is offline   Reply With Quote Quick reply to this message
Old 09-04-2019, 09:47 AM   #8 (permalink)
GFY Racing's Avatar
Member # 136091
I found a few more pictures. Overall they're beefier than the normal shafts, though they still neck down near the carrier splines.
Old 09-04-2019, 09:53 AM   #9 (permalink)
Member # 85771
Fawking A dude, thanks for that info! Those are the same shafts.
Old 09-04-2019, 09:56 AM   #10 (permalink)
GFY Racing's Avatar
Member # 136091
Happy to help. Sorry I don't have more info. I just assumed they were later model shafts and was planning on running them while keeping the others for spares.
Old 09-04-2019, 10:14 AM   #11 (permalink)
Member # 85771
That's enough info to keep my mind from wondering too much. Cause it will go from "I'll just pull the shafts and check" to "Honey, I gotta drive 120 miles to pick up this LS and link mount kit I found for cheap"
Old 09-04-2019, 01:41 PM   #12 (permalink)
Member # 191442
Those are shafts for a jeep equipped with four wheel ABS. It was optional in 1994 and 1995 on YJ's. Also could have come from an XJ with the disconnect axle. The splines are the tone ring for the sensor. If one piece, they could also be ABS equipped XJ, TJ or ZJ shafts. '96 + would have larger u-joints.
Marty, SoCal is offline   Reply With Quote Quick reply to this message
Old 09-04-2019, 07:59 PM   #13 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
The vss tone ring has nothing to do with the 2x spln shafts. Ive worked on hundred if not thousands of jeeps. Ive never seen those. They are not stock shafts.
Old 09-04-2019, 09:18 PM   #14 (permalink)
Member # 16505
Definitely ABS tone rings. I yanked a shaft from an XJ in a junkyard for a spare one time and it had those splined rings on the end of it. I donít recall if I ever actually used it on my YJ or not. I think I may still have it floating around someplace. I have never seen one like that on a YJ, they may well be junkyard XJ shafts though. Being ABS they should also have the larger joint found in the TJ if I am not mistaken. Pretty sure the abs shafts got the bigger joints.
92 Jeep Wrangler.
Old 09-04-2019, 10:50 PM   #15 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
They are all 297 after the 70s. Even todays jks are still 297/760 joints
Old 09-04-2019, 11:04 PM   #16 (permalink)
Member # 16505
You sure about that? They are 260 joints up until I believe the 94 or 95 YJ. TJs moved up to the 297 joints which is part of what makes the TJ shaft swap so popular for YJ guys. (In addition to the one piece inner on the passenger side allowing the elimination of the failure prone CAD). As I recall, the ABS equipped XJs also got the 297 series joints.
92 Jeep Wrangler.
Old 09-04-2019, 11:41 PM   #17 (permalink)
Member # 79509
not talking about the stubs. The inner axle is double spline; yoke isnt part of the shaft.
I concur
Incorrect
I concur
Black Sheep is online now   Reply With Quote Quick reply to this message
Old 09-05-2019, 08:03 AM   #18 (permalink)
Member # 191442
"not talking about the stubs. The inner axle is double spline; yoke isnt part of the shaft."
Need to see pics of that if it's not the normal inner double splined shaft form the YJ right side two piece axle.
The pictured axles that GFY Racing posted are most definitely ABS axles. It's a very rare option on '94 and '95 YJs but ABS was available in those years and the outer stubs do have the tone rings, inner axle on the right side was two piece as they still had the vacuum disconnect system.
Old 09-05-2019, 08:12 AM   #19 (permalink)
Member # 214685
Lots of dumb people. “ThEy ArE tOnE rInGs”
My guess is they may be old aftermarket chromos. I spent many a time in the local yards pulling spare D30 shafts in my earlier years and have never seen one splined like that.
Byro is offline   Reply With Quote Quick reply to this message
Old 09-05-2019, 08:35 AM   #20 (permalink)
Member # 191442
Never say never!
A new Spicer Left shaft is available at Rockauto:
https://www.rockauto.com/en/catalog/...le+shaft,10439
DANA 758151X
Application:
JEEP CHEROKEE 1992-2001
JEEP GRAND CHEROKEE 1993-1998
JEEP WRANGLER 1993-2002
Old 09-05-2019, 08:51 AM   #21 (permalink)
Member # 178200
Why do so few people see the fucking splines sticking out at the end of the yolk on the shaft in question and keep talking about the stupid abs ring...... Holy Fuck!!!!
Old 09-05-2019, 09:09 AM   #22 (permalink)
Member # 79509
Originally Posted by Byro View Post
Lots of dumb people. ďThEy ArE tOnE rInGsĒ
Marty is taking the cake.
Old 09-05-2019, 09:55 AM   #23 (permalink)
Member # 214685
Shit, for sure.
Old 09-05-2019, 10:49 AM   #24 (permalink)
Member # 214670
OP has a OEM zj axle shaft. Spicer presses on a thick plastic washer instead of the little flimsy ones most people are used to.
Can confirm. I have tried to take off one of those pressed on plastic washers. Itís a bitch lol.
Keydet15 is offline   Reply With Quote Quick reply to this message
Old 09-05-2019, 10:59 AM   #25 (permalink)
Member # 85771
Its tough to see in that pic but if you go the sight you can see it. Thanks man.
