Steer me right - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-02-2019, 12:53 AM   #1 (permalink)
renolaw's Avatar
Member # 12908
Steer me right
Oem steering box from 81. Last untouched major component. Works fine but engine is out and doing frame repairs. So why not. Looking at the H1 or aftermarket PSC. Not ready for hydro assist but the latter can be pre tapped for later uograde.
Pros / cons each?
'81 CJ8
'01 2500 HD 8.1/Ali
Life Member BRC
ECV #3691
renolaw is offline   Reply With Quote Quick reply to this message
Old 10-02-2019, 01:03 AM   #2 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Unless you want an actual new box a saginaw is a saginaw.
There are different input and sectors. So.e have a slightly higher or lower ratio than others.
Idk why you think an h1 is anything important but if youre wanting new and hydro later get a psc.
total newb is online now   Reply With Quote Quick reply to this message
Old 10-02-2019, 07:24 PM   #3 (permalink)
renolaw's Avatar
Member # 12908
Many forums cheer the beefy ness and “bolt in” features of the H1 box. Concern are the turns lock to lock. Adds about 3/4 turn.
Psc is nice but spendy. Reviews are mixed. Still on the fence.
'81 CJ8
'01 2500 HD 8.1/Ali
Life Member BRC
ECV #3691
Old 10-04-2019, 01:47 PM   #4 (permalink)
Member # 191442
The H1 box is faster than the 17-1 stock CJ P.S. box. IIRC, it's 12x16-1 variable ratio. Might be able to get a Delco reman one part number 19321422 at Summit.
https://www.summitracing.com/parts/ADO-36G0167.
They have the larger piston and the same input spline as the '76-'86 CJ unit. They have metric hose fittings, so you would also need to change the pump outlet fitting to the metric o-ring style if you have an early CJ. The switch to metric hose fittings was around 1981 or so.
Hope this helps!
Marty, SoCal is offline   Reply With Quote Quick reply to this message
Old 10-24-2019, 06:52 PM   #5 (permalink)
renolaw's Avatar
Member # 12908
Hope this helps!
My engine is a stroked 4.0 built off a 94 4.0 so believe the ps lines can be reused.?
'81 CJ8
'01 2500 HD 8.1/Ali
Life Member BRC
ECV #3691
Old 10-28-2019, 09:05 AM   #6 (permalink)
Member # 191442
4.0l power steering pumps all have the metric o-ring fittings. A YJ or TJ pressure hose will probably fit better than the metric CJ hose with these pumps.
Old 11-03-2019, 04:59 PM   #7 (permalink)
renolaw's Avatar
Member # 12908
After deeper thought am heavily leaning to the PSC box. Get tap for later hydro. With hydro assist Have read if engine dies steering turns to concrete. No manual steering. Might be fun on the freeway/street or dead stick on the trail.
Perhaps a pressure bypass valve to isolate the ram? School me here,
'81 CJ8
'01 2500 HD 8.1/Ali
Life Member BRC
ECV #3691
