NV3550 Internal slave???? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-02-2006, 10:34 AM   #1 (permalink)
ricmitch's Avatar
Member # 55841
I know the NV3550 can replace a AX-15 but can I still use the internal slave cylinder and bellhousing? I was told that I can ..but I would like to know from someone that may have done this swap... I cannot seem to locate an affordable bellhousing with the external slave with all the needed components
such as the slave cylinder ..hoses, bearing fork, bearing, pilot busing....(what ever its called)
1990 YJ 4.2L
I guess I may have to purchase it all from advance adapters but that uses all the cash...
1990 yj AMC 258 with 4.0 head conversion bored .060 over, comp cam, holley 2bbl 33 inch tires 4 inch lift 2in. body lift nv3550 5speed
ricmitch is offline   Reply With Quote Quick reply to this message
Old 03-02-2006, 11:21 AM   #2 (permalink)
Schmozilla's Avatar
Member # 38562
Send a message via AIM to Schmozilla
Are you sure that you have an ax-15?? and not a Pugeot Ba-10.... I dont think that the AX-15 ever came with in internal slave... I did the Ba-10 to ax-15 swap and I used the external slave that came in the ax-15...they are much easier to replace should it ever go bad.
Schmozilla is offline   Reply With Quote Quick reply to this message
Old 03-03-2006, 07:06 AM   #3 (permalink)
Randall Edge's Avatar
Member # 12992
Send a message via AIM to Randall Edge
yep, some of the AX-15's came with an internal slave. I've got complete 3550 from my TJ. I swapped in an auto so I have the clutch and all the little parts. I'm holding it for a guy I worked out a trade with, but if it falls through I might be able to help.
'48 Willys Truck.....sorta......
Randall Edge is offline   Reply With Quote Quick reply to this message
Old 03-03-2006, 08:11 AM   #4 (permalink)
jesster's Avatar
Member # 49468
I'm in the process of helping a friend swap out a 95 AX-15 for an 04 nv3550 It looks like the throwout bearing and clutch fork are identical (both external slave), so I would guess that the bellhousings (even the internal slave ones) are interchangable onto the trannies.
Why would you want to keep the internal slave cylinder though? If you are swapping out trannies anyways, here is an opportunity to upgrade. It sucks when an internal slave cylinder starts leaking and has to be replaced (hours and hours of work), while replacing an external slave cly. only takes minutes... I would think it would be worth the few extra bucks to swap out internal bellhousing and slave cylinder for external while you have it all tore apart. My .02
Jesse
jesster is offline   Reply With Quote Quick reply to this message
Old 03-06-2006, 04:53 AM   #5 (permalink)
ricmitch's Avatar
Member # 55841
!i do agree.. AA want 250.00 for the bellhousing and 150 for external slave kit..and 40.00 for a tcase bracket.....I dont want to break the budget..money is so tight now adays.. my inteneal slave is brand new ..clutch too
Old 03-06-2006, 11:19 AM   #6 (permalink)
Member # 22064
Just find a 94 and later Jeep 4.0 bellhousing set up. That will work as is. When you use the term "internal slave" what you're really talking about is the Jeep Hydraulic Throwout Bearing. It's a poor unit prone to leakage. It will NOT fit onto the NV3550. 93 and earlier I believe used them and the bell is designed to work with them. Go to www.car-part.com and find a stock 94 and later set up. They aren't that expensive and will bolt straight up to the NV3550. Some of them are going for around $40.
Greg
Greg55_99 is offline   Reply With Quote Quick reply to this message
Old 03-06-2006, 12:09 PM   #7 (permalink)
ricmitch's Avatar
Member # 55841
thanks Greg!
there is a yard that has a few of them ... about 150 mi. thanks again
Old 03-06-2006, 06:30 PM   #8 (permalink)
Member # 12992
Heck, I'd sell you all my 3550 stuff for less than half of that. Too bad your not close to Ga.
Old 03-06-2006, 08:15 PM   #9 (permalink)
ricmitch's Avatar
Member # 55841
well if its available let me know if you want to sell it .... I can pay for shipping...
Old 03-06-2006, 08:26 PM   #10 (permalink)
Member # 12992
I had a trade worked out with a guy, but I think he's blowin' me off. Give me until Wednesday evening to get in touch with him. If he's no longer interested then it will be back up for sale.
I have almost everything that was removed when I put the auto in. The pilot bearing and the spacer inside the crank were both trashed, but I have everything else.
Old 03-06-2006, 10:07 PM   #11 (permalink)
ricmitch's Avatar
Member # 55841
thanks ..let me know
Old 03-08-2006, 07:52 PM   #12 (permalink)
Member # 12992
The dude won't return my calls. I guess that means my 3550 stuff is back up for sale. You still need some parts?
Old 03-08-2006, 08:07 PM   #13 (permalink)
ricmitch's Avatar
Member # 55841
yes ..what do you have ...need bellhousing to hook up to 4.0/4.2 throw out bearing fork , slave cyl...what do you have?
Old 03-08-2006, 08:35 PM   #14 (permalink)
Member # 12992
I've got the 3550 with bell and throw out bearing fork, clutch master/slave, brake & clutch pedals for a TJ, 4.0L flywheel + clutch disk + pressure plate, tranny dust shield, 3550 tranny mount adapter. There is probably something I've forgot, but that is most of it.
Old 03-11-2006, 05:23 AM   #15 (permalink)
Member # 12992
Sent ya a PM Rick.
