D35 to 8.25 swap - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-03-2006, 07:38 AM   #1 (permalink)
Member # 27438
D35 to 8.25 swap
I'm assuming it's a direct bolt-in with the exception of the u-bolts but does the driveshaft yoke, flange, joint, blah blah blah bolt right up? I don't have one to compare just yet but would like to get the parts coming so I can swap this out in an afternoon without having to run back and forth.
'13 JKU Rubi with "stuff"
Ex CCS Racer is offline   Reply With Quote Quick reply to this message
Old 03-03-2006, 10:08 AM   #2 (permalink)
Member # 36606
why "upgrade".... to a 8.25 ?? go bigger, all you are getting is a little thicker axle tube and 2 more splines.... go 44 or ford 8.8" for medium-moderate wheeling... just my 2 cents, but yes, when you do a 8.25 swap, everything bolts on, as long as you are taking it out of a jeep of the same make as yours, otherwise the spring perches may need to be relocated
WhiteJeepXJ is offline   Reply With Quote Quick reply to this message
Old 03-03-2006, 10:10 AM   #3 (permalink)
Member # 25999
Send a message via AIM to CanuckJeeper Send a message via Yahoo to CanuckJeeper
I'd go for the 8.8 a lot more than the 8.25" myself!
JP
CanuckJeeper is offline   Reply With Quote Quick reply to this message
Old 03-04-2006, 09:47 PM   #4 (permalink)
Member # 27438
If I could find an 8.8 that was ready to bolt in I'd do it but those at a decent price don't come around often. I've found a newer('97+) 8.25 that's locked and regeared for $325....
Old 03-05-2006, 05:41 AM   #5 (permalink)
Member # 19579
Whatta ya mean by 'bolt-in'?? More often than not - most leaf spring axle swaps are gonna require spring perch removal and/or perch placement for pinion angle adjustment depending on your current setup.
What are you putting it under and what is your current suspension setup??
Is the 8.25" from a Cherokee?? If YES - It's gonna be SOA.
Soooooooo.......
Izzy II: Lifted, locked, and ready to rock!!
Janster is offline   Reply With Quote Quick reply to this message
Old 03-05-2006, 08:39 AM   #6 (permalink)
Member # 33523
You can get complete 8.8s for $150 from the cmc junk yard in Gaston, all you would need is spring perches and shock mounts.
dfvaulter is offline   Reply With Quote Quick reply to this message
Old 03-06-2006, 07:26 AM   #7 (permalink)
Member # 27438
Well I sold my Land Rover and down to one vehicle so I can't have the down time. I could prep it beforehand and do everything where it should be a same day bolt in deal but ya never know what problems will arise.
Old 03-06-2006, 07:32 AM   #8 (permalink)
Member # 25999
That's when you ask your buddies for a backup vehicle
JP
Old 03-06-2006, 07:37 AM   #9 (permalink)
Member # 27438
Btw, I've found a locked and regeared 8.25 for $325 that I intend to put in.
Old 03-06-2006, 07:38 AM   #10 (permalink)
Member # 27438
JP
I hope you aren't referring to the Jetta
Old 03-06-2006, 12:51 PM   #11 (permalink)
Member # 25999
Can you drive a diesel?
(and I do mean the truck)
JP
Old 03-06-2006, 02:21 PM   #12 (permalink)
Member # 27438
Ummmm...yeah.... the Rover was slow and heavy like a diesel and my old YJ steered and stopped like ass. A combination of the 2 would be my expectations.
Old 03-06-2006, 08:39 PM   #13 (permalink)
hitech_hick's Avatar
Member # 62866
Driveshaft length may be an issue, D35's had longer shafts than the chrysler 8.25's, but depending on your setup and amount of lift, it may still work out.
hick
hitech_hick is offline   Reply With Quote Quick reply to this message
Old 03-07-2006, 04:47 AM   #14 (permalink)
Member # 27438
In that case I can go ahead and order a SYE and may be able to save on the buying a ds
Old 03-07-2006, 05:23 AM   #15 (permalink)
Member # 25999
Well just let me know if you need the truck.
JP
Old 03-07-2006, 08:43 AM   #16 (permalink)
Member # 27438
Well I appreciate it. I'm hoping to have it all planned out and everything ready for an afternoon of a direct swap. We'll see
Old 03-07-2006, 01:09 PM   #17 (permalink)
Member # 49539
Send a message via MSN to BCYJ
I think hes alright going with an 8.25. YES it is a direct bolt in application if your putting it under a 'rookie and it came from a 'rookie.
Anything is an upgrade from a D35, even a toyota part.... yes your moving to 29 splines, aren't D44's 30 Splined?(Whats 1 spline? and try finding a 'rookie D44) 8.8's are even upgrades to D44's, but A LOT more fab work.
An 8.25 is a good beginer swap for anyone just getting into the sport. Its an added bonus that its locked and re-geared. I say go with it and upgrade bigger when the time comes, $325 for it is a good deal.
4cyl YJ 33/12.5 BGF AT K/O's, RE4.5ED, AR 767's, Boomerangs, DT Shocks, What Swaybar? AA HD SYE,8.8/LS and 4.88's, HPD30 4.88's, 1750 KG's with all my junk.
BCYJ is offline   Reply With Quote Quick reply to this message
Old 03-07-2006, 11:14 PM   #18 (permalink)
WA-HCRC's Avatar
Member # 39184
IIRC in 97 they went to 29 spline, before 97 they had 27 splines, like my 96
WA-HCRC is offline   Reply With Quote Quick reply to this message
Old 03-08-2006, 05:48 AM   #19 (permalink)
Member # 27438
I was aware of the spline change and mine's coming out of a '99. I ended up going with another unlocked 8.25 I found. It had under 66k miles, was fairly local, cheaper, and as complete as you can get. It should be delivered today as a matter of fact
