amc 20 from '78 CJ fit in my '83 CJ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-05-2006, 08:06 AM   #1 (permalink)
Pigphucker's Avatar
Member # 52990
The rear end locked up in my '83 CJ-5, I found a '78 CJ rear axle local for a bill. What's the difference? I've been told my '83 is narrow track and the '78 is a widetrack? If that's the difference, can I pull the chunk out of the '78 housing and put it in my '83 housing? Thanks
Solid Axle '85 broncho
'91 Toy 4x4 with high performance floormats
Pigphucker is offline   Reply With Quote Quick reply to this message
Old 03-05-2006, 08:12 AM   #2 (permalink)
Member # 32437
Actually, that would be completely backwards. Jeep switched to widetrack axles in '82 (if memory serves) but the CJ-5 never got the widetrack axles from the factory. The 78 will be a narrowtrack (assuming its original) and should be a direct swap in to your '83.
78jeepstang is offline   Reply With Quote Quick reply to this message
Old 03-05-2006, 08:12 AM   #3 (permalink)
RenegadeCJ's Avatar
Member # 40202
your 83 is a wide track the 78 is a narrow track. if both are amc 20's the chunk should interchange tho
RenegadeCJ is offline   Reply With Quote Quick reply to this message
Old 03-05-2006, 07:45 PM   #4 (permalink)
bjb
Member # 56602
might want to check gear ratios too.
bjb is offline   Reply With Quote Quick reply to this message
Old 03-05-2006, 07:54 PM   #5 (permalink)
Member # 18675
Send a message via Yahoo to bspencer
CJ5's never got a wide track from the factory!!!
so if yours is factory it is the same width as the 78...... jsut maek sure the gears are the same or you wont have 4wd
Mountaineer Off Road
bspencer is offline   Reply With Quote Quick reply to this message
Old 03-06-2006, 07:47 AM   #6 (permalink)
Member # 9614
Assuming the gears are the same, you'll actually be trading up (ever so slightly) since '78's had 11" drums in the rear vs. 80's 10" drums.
One catch, get the '78s ebrake cables since making the later ebrake cables fit the older brakes is a pain.
Other than that, it's all bolt-in.
Choose Life. Preferably Cinnamon.
fullygruntled is offline   Reply With Quote Quick reply to this message
Old 03-06-2006, 09:41 AM   #7 (permalink)
Pigphucker's Avatar
Member # 52990
Thanks for the info guys . One thing I did fail to mention is that the '78 is a CJ-7, and my '83 is a CJ-5. Does that change anything? Is it a still basically a bolt in? I'll measure when I get off work, but ya'll might already know. Thanks
Old 03-06-2006, 09:43 AM   #8 (permalink)
Member # 9614
Nope, changes nothing. Aside from any gear ratio quesitons, you're set.
Old 03-06-2006, 11:37 AM   #9 (permalink)
Member # 65332
I put 82 axles under my 79 with no mods. the 82's are wider had 4.56, superior 1-pc and lock-right up front. I prefer the added width as well. I also went from and off centered rear quadra-trac to a D300, and these where the quickest way to get back on the trail. Of course I wasnt on the trail too long before I wanted to swap out the th400 in favor of a Ford T-18.The 400 ran great, just not behind the 258, so Im down again and wish I would have done all of it at one time, full width 60's and call it done for a week or two.
fishotro is offline   Reply With Quote Quick reply to this message
Old 03-06-2006, 05:50 PM   #10 (permalink)
Pigphucker's Avatar
Member # 52990
JEEEEEZ FUCKIN LOUISE!!!! Thanks for your life story
Old 03-06-2006, 07:07 PM   #11 (permalink)
Member # 18675
not all 78's had the bigger brakes
Old 03-07-2006, 06:24 AM   #12 (permalink)
Member # 9614
I thought they ran the 11" brakes up through the 70's?
Old 03-07-2006, 08:20 AM   #13 (permalink)
Member # 18675
nope actually i believe the transition year was 77 but it may have been 78.... 76 they had the big brakes and some of the fronts were drum i think almost everything 77 up has the 10" brakes and front discs
Old 03-07-2006, 08:20 AM   #14 (permalink)
Member # 18675
now the 78 front should have the more prefered 6 bolt hubs instead of the later 5 bolt hubs too
Old 03-07-2006, 08:48 AM   #15 (permalink)
piratebuggy's Avatar
Member # 53597
My 78 CJ5 has 11" drums rear, disc front. I have a 79 spare axle w/10" drums. Not sure about the hub bolt count offhand.
78 Jeep CJ-5 304 ---setting off car alarms with extreme prejudice.......
Currently rebuilding from the new TDK frame on up, should be cool
piratebuggy is offline   Reply With Quote Quick reply to this message
