74 cj distributor option question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-05-2006, 06:54 PM   #1 (permalink)
Member # 67867
we have a 1974 cj 5 with an old six cylinder and points distributor.
the points have got to go . we would just like to go to the local parts store and get a rebuilt distributor and controll box .
what about a later model jeep ? if so what year did jeep change to electronic
what about a ford or a chevy system?
speaker wire is offline   Reply With Quote Quick reply to this message
Old 03-05-2006, 08:25 PM   #2 (permalink)
Member # 33067
Just buy a distributor from old chevy's 6 cil in line, Malibu's 77 to 81 had those, make sure to buy the one that come with the coil in the cap, you just have to change the gear (remove the gear from the new distributor and use the gear from your original), then just put the + wire from the old coil in the new one and that's it, you don't need a module or any other shit...
Make sure to ask for the Chevy HEI distributor.
I hope you know how to install a new distributor , if don't emailme
[email protected]
Silveradomx is offline   Reply With Quote Quick reply to this message
Old 03-06-2006, 05:34 AM   #3 (permalink)
Member # 65637
Youll have to grind the amc gear alittle bit to install it on the HEI.Or you could find a v8 gear but I forget the exact years.Think its like 80-84 maybe.I assume you have a 232 6cyl if so you can also do the ford TFI upgrade.Very simple also.
My1stNiceJeep is offline   Reply With Quote Quick reply to this message
Old 03-06-2006, 07:28 PM   #4 (permalink)
CSP
Member # 1533
Sorry but the TFI upgrade isn't simple if he's got a points distributor. It only works on the Duraspark II dizzy used on '78 and up CJ's.
speakerwire do a Google search for "Jeep HEI upgrade" on the rest of the web. It's been well documented in many websites.
CSP is offline   Reply With Quote Quick reply to this message
Old 03-06-2006, 07:37 PM   #5 (permalink)
piratebuggy's Avatar
Member # 53597
Or-as an alternative-Pertronix make electronic conversions for every distributor I've ever heard of. Usually easy to install,and the two different vehicles I've got them in have been running and starting better for more years than I can remember off hand(10+ years).
78 Jeep CJ-5 304 ---setting off car alarms with extreme prejudice.......
Currently rebuilding from the new TDK frame on up, should be cool
piratebuggy is offline   Reply With Quote Quick reply to this message
Old 03-07-2006, 06:49 AM   #6 (permalink)
Member # 65637
ICIC
Ive dealt with alot of JEEP CJs but all of them are/were 80 and up.Sounds like the HEI would be easiest then if he has points.
