I want myABS system gone. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-06-2006, 10:10 AM   #1 (permalink)
Member # 24612
Question I want myABS system gone.
I have an 89 xj with the abs braking system. I was wondering how do I disconnect that worthless system and just have regular non-abs brakes? I'm sure someone has done this before so any help would be great.
sik4wheeler is offline   Reply With Quote Quick reply to this message
Old 03-06-2006, 10:42 AM   #2 (permalink)
COVEJEEPSXJ's Avatar
Member # 36128
I am not sure if you have the same system on your '89, but I removed the fuses, relays and sensors from my '96 XJ and everything is fine.
[B][I]"132 and Bush I've got him at gun point, OK gun point, 132 and bush, cover is code 3"[/I][/B]
[QUOTE=87manche;10827893]just color it in with a sharpie.
[/QUOTE]
COVEJEEPSXJ is offline   Reply With Quote Quick reply to this message
Old 03-06-2006, 10:57 AM   #3 (permalink)
Member # 24612
I'll give that a try. Awhile back I removed the fuses but that only made things worse. The reason I am mainly doing this is because me abs pump never shuts offs.
Old 03-07-2006, 07:12 AM   #4 (permalink)
Member # 24612
bump
Old 03-07-2006, 08:56 AM   #5 (permalink)
piratebuggy's Avatar
Member # 53597
Removing the fuse should disable the system from working. There would have to be some kind of short for it to still get power. Why not instead reroute the brake lines and remove the system all together. This wouldn't be too tough for a good experienced mechanic,someone that knows how to double flare some lines and plumb the lines around the ABS to the brakes ,bypassing the system all together.Just need the lines to run to the proportioning valve from the master cylinder just like in the old days. It may be simpler to find the short and fix the wiring,ABS can be a lifesaver on the street.
78 Jeep CJ-5 304 ---setting off car alarms with extreme prejudice.......
Currently rebuilding from the new TDK frame on up, should be cool
piratebuggy is offline   Reply With Quote Quick reply to this message
Old 03-07-2006, 09:25 AM   #6 (permalink)
Member # 56486
I just removed the sensors from mine on my 95 YJ. No problems other then the light on the dash that says ABS is always on. I did not use a proportioning valve. I did all of this when I installed an 8.8 rear axle in it. Everything is working just fine. You could always try disconecting the power source from the ABS pump also.
Mr. 95YJ is offline   Reply With Quote Quick reply to this message
Old 03-07-2006, 09:31 AM   #7 (permalink)
Member # 36128
I have black electrical tape covering mine!!
[/QUOTE]
Old 03-07-2006, 05:25 PM   #8 (permalink)
Member # 2790
Why not just pull the bulb??
Russ
hy_desert_4wheeler
46 Dodge WC15--67 M715--85 Jeep CJ10A--06 Dodge Ram2500Quad cab Cummins--94 Suburban--06 Ridgeline-
hy_desert_4wheeler is offline   Reply With Quote Quick reply to this message
Old 03-07-2006, 06:08 PM   #9 (permalink)
Member # 2331
On my 90 XJ the ABS went south. The unit under the coolant tank on the passenger side went out. Instead of replacing it, I yanked that unit, the lines to and from it, and the master cylinder that is used with the ABS system.
I went to the parts store and got a MC and vacuum booster setup for a 90, and it bolted right in. A couple of double flared brake lines and a proportioning valve later, I was in business...
Need to still yank the rest of the ABS components, but I can drive the thing now...
Warlock is offline   Reply With Quote Quick reply to this message
Old 03-08-2006, 05:41 PM   #10 (permalink)
Member # 53597
Unless the ABS is integral w/the master cylinder ,the master cylinder and power booster will work just fine w/o the ABS system. There is no reason to change to anything different,the brake system operates independent of the ABS unless it is activated. In other words,there is nothing different about the brake system when you remove the ABS system,and it works the same as before,just no ABS function.
Old 03-08-2006, 06:03 PM   #11 (permalink)
Member # 2331
In my case, when that unit went bad, braking got real hard because there is no power booster.
Easier to swap it out, in my case.
