Newbie jeep questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-07-2006, 02:28 PM   #1 (permalink)
Member # 68165
I have a few quik questions regarding 1989 YJ. I am Ford truck man that is switching to a Jeep and dont know much about them in there stock form.
- what axles and t-case are on them stock?
- do they have carbs or injected?
- its a 5spd how good are these transmissions?
Thats all, I just dont know anything about Jeeps.
Thanks
Grounhog is offline   Reply With Quote Quick reply to this message
Old 03-07-2006, 02:37 PM   #2 (permalink)
Member # 48233
Ure lucky its Tuesday
Axles d30/35 T-case np31
87-90 Carbed 91-present injected 6 cyclinders; the 4 are injected
from the sound of it you aren't hardcore soo yes its goo
Doc Holiday13 is offline   Reply With Quote Quick reply to this message
Old 03-07-2006, 02:57 PM   #3 (permalink)
Member # 68165
Thanks for the reply!! No Im not hardcore when it comes to Jeeps, but Im working on it.
Old 03-07-2006, 03:24 PM   #4 (permalink)
phattdraggon's Avatar
Member # 50975
there were 2 different manual transmissions in the 89' wranglers. the piece of shit peuogot (ba-10) and the slightly better ax-15. for identification purposes the ba-10 will be split lengthwise.
the stock carter carbs are ridiculous. throw a motorcraft 2100 on it (1.08 venturis).
phattdraggon is offline   Reply With Quote Quick reply to this message
Old 03-07-2006, 04:15 PM   #5 (permalink)
Member # 9614
Very quick and overgeneralized assessment of late 80's Wranglers:
1. Remove the entire powertrain and axles and discard in whatever way pleases you.
2. Install the complete powertrain and axles from a late 80's Grand Wagoneer or late 70's Ford 1/2t truck.
Very nice build platforms, though.
Choose Life. Preferably Cinnamon.
fullygruntled is offline   Reply With Quote Quick reply to this message
Old 03-07-2006, 04:40 PM   #6 (permalink)
Schmozilla's Avatar
Member # 38562
Send a message via AIM to Schmozilla
1/2 ton truck??? how about a 1 ton truck...
Schmozilla is offline   Reply With Quote Quick reply to this message
Old 03-07-2006, 06:30 PM   #7 (permalink)
Member # 68165
Thats what Im hoping to do, I have 2 D60's Im going to get from a friend. I think Im going to start with the axles, gears and suspension first seeing that I have the D60's available. The jeep has a newer 4.2 I6 the guy just put in so I hoping with bigger gears I can get away with some big tires until I update the drivetrain. As soon as I sell my built F-250 truck I will have a few bucks to put into the jeeps drivetrain. It seems from what I read that some guys build up there I6's and run them in there rigs, is this not the case. Thanks again
Old 03-08-2006, 05:49 AM   #8 (permalink)
Member # 9614
Sure, that's fine too.
First, that's a very nice friend. The number one 87-95 Wrangler problem is the axles. Sounds like you have that solved.
The 4.2 is a good motor, but as mentioned earlier needs a different carb or a FI setup in its Wrangler inception to avoid headaches.
You'd probably have the AX15, then, which should handle the 4.2 well enough. The NP231 at most would want a slip yoke eliminator.
Old 03-08-2006, 01:37 PM   #9 (permalink)
Member # 68165
I just talked to my neighbor today who has a CJ7 that he swaped a 302 and trans into the jeep with a D300 T-case,it all must still be wired up but Im thinking of going this route. The engine/trans is brand new, plus it is a really clean jeep all grade 8 bolts throughout, poly bushing, SS brake lines etc. I could get it for $4500.00 as it sit what ya think? He has all the computers wire harness for the motor and trans. Just and idea.
