fullwidth dana 44 spring pad help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-11-2006, 10:05 AM   #1 (permalink)
Member # 54975
Send a message via AIM to Plato2k5
i need to move that spring pad in about a 1/4 for it to be centerd correctly. Is it common that you have to notch away at the pumpkin for the pad to fit?? Also for wms to wms i got 66 1/4" does that sound about rite? This is also going under my 88 yj
Plato2k5 is offline   Reply With Quote Quick reply to this message
Old 03-11-2006, 03:21 PM   #2 (permalink)
Member # 37184
Seams to me if the 1/4 inch is critical, it would be easy enough to design a spring pad to fit over the edge of the pumpkin. May have to build it a little taller, with a little more axle contact next to the center section to insure a good weld. I'd rather do that than to notch the center section. My .02
Bubba_Jeep is offline   Reply With Quote Quick reply to this message
Old 03-12-2006, 02:07 PM   #3 (permalink)
Member # 62185
Look into Mountain Offroad (M.O.R.E.). They have offset units for the YJ axle when doing spring over. http://www.mountainoffroad.com/more.htm They are quality parts. Ed
Hipower is offline   Reply With Quote Quick reply to this message
Old 03-12-2006, 07:56 PM   #4 (permalink)
Member # 61220
yeah, i'd definitely make a spring perch to go over the pumpkin rather than grind away at it in an attempt to use the perch you have now.
jeepinjimjz is offline   Reply With Quote Quick reply to this message
Old 03-12-2006, 09:11 PM   #5 (permalink)
Member # 54975
Thanks for all the tips. I got it all figured out, I just outboarded the springs and it worked perfectly to clear the pumpkin.
Old 03-13-2006, 01:38 AM   #6 (permalink)
Member # 11973
what * angle did you weld them to give you your pinion angle?
Murfman is offline   Reply With Quote Quick reply to this message
Old 03-14-2006, 11:44 AM   #7 (permalink)
Member # 54975
its all fubbard up... i forget the degree but i did the math and it should of neted me 5*....but its sittin under there with just the weight of the frame on it and its at 15*...so i'll just have to re-do it once everything is back on the frame
