no spark... no start - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-12-2006, 04:59 PM   #1 (permalink)
Member # 47111
Ok, this is my DD... 89 cherokee limited 4.0 auto. I parked it for a few hours, came back and did not start. It is getting fuel but no spark. distributor is good, new plugs/wire, cap, rotor, and i just changed the coil. Any thoughts? thanks.
bignate is offline   Reply With Quote Quick reply to this message
Old 03-12-2006, 05:37 PM   #2 (permalink)
Cue-Ball's Avatar
Member # 17311
Check all your conections. Going dead that quick kind of hints at a loose connection.
Nex Pro Evinco [COLOR="Black"]"Death Before Defeat"[/COLOR]
Cue-Ball is offline   Reply With Quote Quick reply to this message
Old 03-12-2006, 07:53 PM   #3 (permalink)
piratebuggy's Avatar
Member # 53597
Agreed-need to check connections-the ignition module is another possibility,they can work one second and not the next.
78 Jeep CJ-5 304 ---setting off car alarms with extreme prejudice.......
Currently rebuilding from the new TDK frame on up, should be cool
piratebuggy is offline   Reply With Quote Quick reply to this message
Old 03-13-2006, 12:39 AM   #4 (permalink)
Member # 11973
ignition module
Murfman is offline   Reply With Quote Quick reply to this message
Old 03-13-2006, 09:41 AM   #5 (permalink)
Member # 34020
unplug your crank position sensor then plug it back in it should start. it is located at the back of the engine next to the valve cover, should be a 3 pin weather pack. this happens to a lot of people. it means that yoou cps is starting to go bad.
I'd rather have a bad attitude and be right than be a cheerful idiot
chevytruckzach is offline   Reply With Quote Quick reply to this message
Old 03-13-2006, 10:05 AM   #6 (permalink)
Cue-Ball's Avatar
Member # 17311
this was my next guess.
