No Tail Lights Help 93 wrangler - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-12-2006, 06:33 PM   #1 (permalink)
Member # 41794
Question No Tail Lights Help 93 wrangler
I need help. All of my light's work including the brake lights but, the tail lights do not work. Could it be the headlight switch since they should come on when I turn on the headlights? Or is there some other place I should be looking. I am trying not to have to tear into all of the wires if I don't need to. Has anyone else had this problem?
RonnieRotten is offline   Reply With Quote Quick reply to this message
Old 03-13-2006, 05:38 PM   #2 (permalink)
Discount!
dog walker's Avatar
Member # 156
Send a message via ICQ to dog walker
Nobody with a YJ has had this problem? I thought maybe it may be a common issue with YJ's.
Jeff Fretwell
72 FJ40
67 FJ45
83 Toyota 4x4 LB
04 UJZ100
1990 FJ62
dog walker is offline   Reply With Quote Quick reply to this message
Old 03-14-2006, 07:39 AM   #3 (permalink)
Member # 41969
The headlight switch is rather inexpensive so that would be a great place to start. I also would look at the ground wires.
08 LTZ Duramax
Top Shop Champion Spring 2006-Team Toumbs Repair
Top Shop Champion Fall 2006---Team Toumbs Repair
Originally Posted by Dan Dibble
"In my opinion this is a motor sport so I like to have one. Any more questions "
Dan
botiejeep is offline   Reply With Quote Quick reply to this message
Old 03-14-2006, 09:26 AM   #4 (permalink)
Member # 65332
its really not that complicated of a wireing system, dive in and check it out, make sure you have a some sorta tester.
fishotro is offline   Reply With Quote Quick reply to this message
Old 03-14-2006, 03:23 PM   #5 (permalink)
Member # 32246
Check the fuses too... My taillights went out once but my dash lights were also out. They were on the same fuse in my 95 YJ
EDIT: headlights worked the whole time my dash lights and tail-lights were out. Brake lights still worked.
JeepnYJ is offline   Reply With Quote Quick reply to this message
Old 03-14-2006, 03:42 PM   #6 (permalink)
Member # 52770
I would say it would have to be the switch or the ground wire. My buddy had this problem and it was only the switch but I think it could also be a ground wire too.
Jeep9515 is offline   Reply With Quote Quick reply to this message
Old 03-14-2006, 04:43 PM   #7 (permalink)
Discount!
dog walker's Avatar
Member # 156
I havn't looked at it ( Ron's my brother in law), but he did mention that he tryed a different switch and had the same problem. Sounds like a ground issue to me as well. Maybe a loose connection under the dash, or back at the rear of the frame somewhere.
Jeff Fretwell
72 FJ40
67 FJ45
83 Toyota 4x4 LB
04 UJZ100
1990 FJ62
Old 03-16-2006, 10:06 PM   #8 (permalink)
Member # 41794
Well I figured it out. On the headlight switch there are two seperate power wires coming in. one of those is for the tail lights and mine didn't have power. Add power and it's all good. Thanks for the input.
