Precision Brand U-Joints - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-15-2006, 08:39 AM   #1 (permalink)
Member # 6426
Are they any good? I can get a set for about half of the price of spicers for my 60 front. Running 37's.
Couple of YJ's without leafs.
..and a TJ project in the making
87YJ is offline   Reply With Quote Quick reply to this message
Old 03-16-2006, 08:32 AM   #2 (permalink)
Member # 14270
Those are the ones Napa uses now, right? I think I had a set of those a bunch of years ago, wore em out in about 5K miles, with 31s. Not worth it for a trail vehicle, maybe a street vehicle. Spicers ARE worth the money.
--Matt
egon is offline   Reply With Quote Quick reply to this message
Old 03-16-2006, 09:03 AM   #3 (permalink)
Member # 47977
I held out for the spicer. Up here (canada) it was Neapco and Precision but no one could tell me anything about them. Local parts shop wanted $70.00 EACH for these. Wouldn't even quote me spicers. I bought spicers on ebay.
ksmith is offline   Reply With Quote Quick reply to this message
Old 03-16-2006, 12:46 PM   #4 (permalink)
butch6924's Avatar
Member # 29636
Send a message via Yahoo to butch6924
I've used the precision ones before. They're better than the ones that AZ sells but not quite as good as the Spicer's. I've been told they're also made in China if that means anything to you.
butch6924 is offline   Reply With Quote Quick reply to this message
Old 03-16-2006, 01:16 PM   #5 (permalink)
Member # 46444
I personally would only run spicers myself.
frankiefire702 is offline   Reply With Quote Quick reply to this message
Old 03-16-2006, 08:31 PM   #6 (permalink)
Member # 61360
same here spicers ar better i ran these with my 8.8 and i was changing them atleast 2 to 3 times a month
ribsyj is offline   Reply With Quote Quick reply to this message
Old 03-16-2006, 08:33 PM   #7 (permalink)
Member # 61360
same here spicers are better i ran those percison with my 8.8 and i was changing them atleast 2 to 3 times a month i started going with spicers i was chaning them about once every 2 months
Old 03-16-2006, 09:07 PM   #8 (permalink)
kris1351's Avatar
Member # 40704
Get the Spicer solid ones at that. They don't have greasable fittings, but they are quite a bit stronger.
Kris
Buy it, use it, break it, fix it, trash it, change it, melt - upgrade it
- Free Pic Hosting & Blogs
- Premier Web Hosting Solutions
kris1351 is offline   Reply With Quote Quick reply to this message
Old 03-17-2006, 02:15 AM   #9 (permalink)
Member # 63690
Personally, I have had fairly good luck with Precision U-joints. Both in the
drivesafts & the front axle.
The key is to get the "super strength" units with the case hardened body.
Not the "heavy duty" ones.
GeepRX is offline   Reply With Quote Quick reply to this message
Old 03-17-2006, 09:10 AM   #10 (permalink)
Member # 6426
Picked up the Spicers. Did get a Precision (was too cheap to pass up - $22) to carry as a trail spare. Precision joint is greasable (no solid) but is stamped MADE IN THE USA.
Old 03-22-2006, 12:04 PM   #11 (permalink)
Member # 44607
I had a Precision (on rear drive shaft) that lasted 2 winter months. It was properly installed and greased. The needle bearings disintegrated.
NAPA replaced it for me, but I'd never want that in the Jeep again. It's in the trails spare box.
TeamCNY is offline   Reply With Quote Quick reply to this message
