9" Front Axle? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-15-2006, 04:05 PM   #1 (permalink)
Member # 39045
9" Front Axle?
I know Currie makes a 9" high pinion front axle. Are their any other companies making one?
Anthony
Yota Tony is offline   Reply With Quote Quick reply to this message
Old 03-15-2006, 04:22 PM   #2 (permalink)
hotwheelsYJ's Avatar
Member # 32401
Send a message via Yahoo to hotwheelsYJ
http://truehi9.com/ for the high 9" third. If your gonna spend the $$$ get the best.
Curries have thier place but are only rated for a 37" tire
Housings can be had @
http://www.hudlowaxle.com
http://www.sunrayengineering.com
http://www.diamondaxle.com
and many others
hotwheelsYJ is offline   Reply With Quote Quick reply to this message
Old 03-15-2006, 05:56 PM   #3 (permalink)
Member # 40761
full circle performance formerly skunkworks can build you one with the currie center section and with 1ton outters and high clearance it for you. They are in Pottstown PA.
R&S custom fab buggy, LSX, Team MARR #696
wgilbertpt is offline   Reply With Quote Quick reply to this message
Old 03-16-2006, 07:13 AM   #4 (permalink)
kris1351's Avatar
Member # 40704
http://www.sunrayengineering.com/
They have the best 9"s that I have found.
Kris
Buy it, use it, break it, fix it, trash it, change it, melt - upgrade it
- Free Pic Hosting & Blogs
- Premier Web Hosting Solutions
kris1351 is offline   Reply With Quote Quick reply to this message
Old 03-19-2006, 07:53 PM   #5 (permalink)
Member # 67386
Send a message via AIM to HsOffRoad
I can build you one - D44 outers, D60 outers, you name it we can build it. My shop's just outside Philadelphia PA though... a bit of a hike for you.
"Shut Up And Wheel Your Junk" - UROC/NEUROC Super-Mod Team #143
HsOffRoad is offline   Reply With Quote Quick reply to this message
Old 03-20-2006, 07:32 AM   #6 (permalink)
Member # 4099
Send a message via AIM to JEEP_TJ_FREAK Send a message via Yahoo to JEEP_TJ_FREAK
Ditto.
Screw you guys I'm going home.
JEEP_TJ_FREAK is offline   Reply With Quote Quick reply to this message
Old 03-20-2006, 07:41 AM   #7 (permalink)
Pat98TJ's Avatar
Member # 23629
Send a message via AIM to Pat98TJ
Shaved 35 spline HI 9 w/ D60 outers. 3 stub shafts go in that axle.
MORE INFO HERE
The best deals are at
Pat98TJ is offline   Reply With Quote Quick reply to this message
Old 04-01-2006, 07:25 PM   #8 (permalink)
Member # 31158
MORE INFO HERE
Hi 9"?????
Joel77 is offline   Reply With Quote Quick reply to this message
Old 04-01-2006, 08:10 PM   #9 (permalink)
Member # 41969
I would assume it is upside down
08 LTZ Duramax
Top Shop Champion Spring 2006-Team Toumbs Repair
Top Shop Champion Fall 2006---Team Toumbs Repair
Originally Posted by Dan Dibble
"In my opinion this is a motor sport so I like to have one. Any more questions "
Dan
botiejeep is offline   Reply With Quote Quick reply to this message
Old 04-02-2006, 09:09 AM   #10 (permalink)
jeeplord's Avatar
Member # 28273
It's a 9" front, all it takes to make it HP is get a Hi-9
You are typically going to get your 3rd member and housing from different places if you are a good shopper
[QUOTE=kodiak1232003]"RUN, WHITE PEOPLE!! RUN!..SAVE YOUR FAWKING SELVES!!!" or some sh#t, in broken engrish...."[/QUOTE]
jeeplord is offline   Reply With Quote Quick reply to this message
