few small question on running dana 60's in a TJ - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-16-2006, 06:18 AM   #1 (permalink)
Member # 62903
Send a message via AIM to prostock3
im in the process of putting on a dana 60 front, and a 14bolt rear in my TJ, im going with the stock wheelbase lenght, and was just seeing if you guys had problems with the rear axle rubbing on the gas tank when flexed? and how you guys ran your tie rods up front to go to the steering box..yea i know i shouldnt but im running the stock steering box for a while to i can do a redneck ram..any help would be great...also i will be posting a build up shortly as i cont. along with it
2009 Twisted Customs buggy----sold
Next buggy build after the garage is finished.
prostock3 is offline   Reply With Quote Quick reply to this message
Old 03-16-2006, 07:11 AM   #2 (permalink)
kris1351's Avatar
Member # 40704
If you have adj CAs then you can set where the axle will sit under there and away from the gas tank. Personally I would move the gas tank up and give the axle more space to be pushed back. It is gonna be tight up front if you keep the stock setups, I barely cleared when I put the Waggy44 in mine.
Kris
Buy it, use it, break it, fix it, trash it, change it, melt - upgrade it
- Free Pic Hosting & Blogs
- Premier Web Hosting Solutions
kris1351 is offline   Reply With Quote Quick reply to this message
Old 03-16-2006, 07:16 AM   #3 (permalink)
UCTJ's Avatar
Member # 51571
Its gonna be very close with the 14 bolt and the gas tank hitting, I smacked my old 8.8 on my gas tank, was running much lift though. Also how big a tire are you running? With that big a rear axle you need some serious tire or your gonna drag that pumpkin around, and if you go too tall w/out a stretch...gonna be tippy....
But you can always look at a fuel cell to give the 14 bolt lots of room.
UCTJ is offline   Reply With Quote Quick reply to this message
Old 03-16-2006, 07:19 AM   #4 (permalink)
Member # 62903
im going to 38.5" and yea my 8.8 rubbed a little too, so thats why i was wondering...there going to be full width, stock wheelbase..long arm so i think i might be alright
