Atlas Leaking - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-16-2006, 07:36 AM   #1 (permalink)
Member # 51646
Exclamation Atlas Leaking
My Atlas II seems to be leaking and I'm having issues tring to track it down. I, took some picks of the Atlas right after driving it last night. It doesn't seem to be the breather, but it did have oil all down the front of it, In the first image, there was a drop of oil near the arrow and this hole at the top. I'm not axactly sure what the hole is or if anythign should be in it. The second image is where it was wet from oil. Ideas?
3sight is offline   Reply With Quote Quick reply to this message
Old 03-16-2006, 07:52 AM   #2 (permalink)
Member # 38563
degrease the entire thing then add some tracer dye to it. You will need a blacklight or florescent light, whatever the dye glows under
84' M1031 CUCV 37's, 8kW gen
Pietro is offline   Reply With Quote Quick reply to this message
Old 03-16-2006, 12:36 PM   #3 (permalink)
Member # 51646
Might try the tracer dye soon, anyone know what the hole is the arrow is pointing at in the first image?
Old 03-16-2006, 03:36 PM   #4 (permalink)
Member # 38563
no idea, but it looks like the oil is coming from the front output bearing plate, the one with the 4 bolts holding it in. Can't be too hard to change, just a little RTV. It also looks like the entire sight tube is filled with oil. Isn't that a little high?
Old 03-16-2006, 04:14 PM   #5 (permalink)
Member # 62189
Not over filled is it? Mine weeped some but ended up being over filled.
BadYj is offline   Reply With Quote Quick reply to this message
Old 03-16-2006, 04:20 PM   #6 (permalink)
2stroke's Avatar
Member # 8981
is the tranny leaking into the t-case overfilling it?
2stroke is offline   Reply With Quote Quick reply to this message
Old 03-16-2006, 06:35 PM   #7 (permalink)
Member # 51646
Actually, the tube is empty. Talked to AA this afternoon. They said that hole is there for other types of vechicles that have a vaccum hose and that is should be sealed for Jeeps. It's actually threaded so I put a bolt in there after work, haven't had a chance to drive it since then so I'll see if it helps.
They also suggested cleaning it with oil remover, driving it for a few miles and then checking to see where oil is coming out.
