Fuel Line connection on a 93 XJ - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-18-2006, 09:44 PM   #1 (permalink)
TNRanger's Avatar
Member # 22676
Send a message via ICQ to TNRanger Send a message via AIM to TNRanger
Installed a 93 XJ 4.0 in an 87 YJ... Which connection on the fuel rail is send and which is return? Does the sending line go into the FPR, or the return into the FPR???
95 YJ 4 links f/r, D60/14b 5.8/c6/203/205 115.5"wb
90 Ranger 5.0/435/205, D44/D60
04 F-250 PSD
TNRanger is offline   Reply With Quote Quick reply to this message
Old 03-21-2006, 05:47 PM   #2 (permalink)
Member # 38303
On the front of your fuel rail you will see a round can with a vacum line on it. This is your fuel pressure regulator, and that fuel fitting is your return. Connect it to the old return line (1/4") that the bypass of the old fuel filter went to. The other fitting on the fuel rail (larger) goes to the output(pressure) side of the fuel pump. There you go....
mrs.jeepgod is offline   Reply With Quote Quick reply to this message
Old 03-21-2006, 05:49 PM   #3 (permalink)
Member # 38303
