something squeaky on my xj??( not engine) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-23-2006, 10:59 AM   #1 (permalink)
thecherokeekid's Avatar
Member # 63555
Send a message via Yahoo to thecherokeekid
something on the front of my xj like around the suspension, wheels etc... is making a squeaking noise.. im not too educated on what bearings and things are up front, also could it be the shocks?( les scwab )
free advice is worth the price you pay
thecherokeekid is offline   Reply With Quote Quick reply to this message
Old 03-23-2006, 01:42 PM   #2 (permalink)
Member # 53490
depending on how much work you put into your jeep, all lifted vehicles make squeaks grumbles and groans. You should prolly put some more specs on what exactly is going on and specs about your vehicle.
Cherokee_HxC is offline   Reply With Quote Quick reply to this message
Old 03-23-2006, 03:31 PM   #3 (permalink)
WA-HCRC's Avatar
Member # 39184
were are you at in washington? if your near kirkland, i'll tell you what it is for 20 bucks ok? renew my star and i'll tell you whats wrong with it.
WA-HCRC is offline   Reply With Quote Quick reply to this message
Old 03-24-2006, 07:47 AM   #4 (permalink)
Member # 24300
Might be the front driveshaft, needs to be disassembled and cleaned.
BlueAngel is offline   Reply With Quote Quick reply to this message
Old 03-24-2006, 10:56 AM   #5 (permalink)
Member # 63555
i belive the cherokee drive shaft in front doesnt rotate unless locked. its other jeeps the move all the time.. still im not sure on that one
as for my jeep specs its a 1994 xj 3 1/2 tough country lift with 31" rvts( les schwab specials) also its the high output 4.0 but i doubt that will matter..
also what in the engine could it be? belts, pulleys?
Old 03-24-2006, 02:19 PM   #6 (permalink)
WA-HCRC's Avatar
Member # 39184
probably the front shaft, the dana 30 pretty much has drive flanges on it, the driveshaft is always spinning since it doesnt have hubs, the 4 wheel drive disconnect is in the transfer case, i just rebuilt my front shaft last night, new ball and socket assembly and three u joints. a harbor freight ball joint/u joint press makes dissasembly much easier, as does a bench vise to grab the half way out u joint caps and twist them out. easy way to find out is to pull out the front driveshaft and see if the squeeking stops. an even easier way to find out if its the engine is rev the engine up while your already rolling, if the squeeking gets faster, its the engine, if it stays the same speed, its the driveshaft. the driveshaft bolts are 5/16 IIRC.
Old 03-25-2006, 12:56 AM   #7 (permalink)
Member # 69306
Easy way to tell if it's the engine or something else: does it make the noise while parked with the engine running? If so check the harmonic balancer to see if the rubber ring is coming out. I just replaced mine this week with a squeak at pretty much all rpms but idle. Hope it helps.
O.D. is offline   Reply With Quote Quick reply to this message
Old 03-26-2006, 09:18 PM   #8 (permalink)
Member # 42809
My bet is on the centering assembly on the front drive shaft. Pull the shaft, drive around and see if it squeeks, report back.
YJ on Tons with Stickies
[QUOTE=robbybobby;9644636]duh bro- momentium.....i have my own special technique- haul Mother F-ng balls at the hill till i am standing alone at the gawd danged top.....[/QUOTE]
muddy_xj is offline   Reply With Quote Quick reply to this message
