CB Antenna Mount on Spare tire Rack? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-24-2006, 07:30 PM   #1 (permalink)
WIKD 281's Avatar
Member # 33625
Hello there. I am trying to mount my cb antenna to my spare tire rack and have few quesitions. I bought a thru fitting from radio shack that enables me to mount the cb antenna on the top of it and then I screw the cb antenna wire into the bottom. Is it ok that this thru fitting touches the metal spare tire rack? Or is supposed to be mounted on plastic? Also, Any other better ideas of how to mount and cb antenna on a jeep?
Thanks for any help.
Harold
WIKD 281 is offline   Reply With Quote Quick reply to this message
Old 03-24-2006, 07:36 PM   #2 (permalink)
WIKD 281's Avatar
Member # 33625
Old 03-24-2006, 07:52 PM   #3 (permalink)
Member # 13055
That will work. Although you may want to add a spring between the antenna and mount. You want metal-to-metal contact between the antenna mount & rack, then between the rack & body/frame. Your antenna is 1/4 wave and the vehicle itself is used to make the other 1/4 wave. Any plastic or rubber between them would just work as an insulator. Make sure you tune the antenna after you have it mounted and install the radio.
I would suggest a little time spent reading/researching the basic's on how CB's work, installation, & SWR. There is a tone of excellent information available from Firestik.
http://www.firestik.com/Tech_Docs.htm
Stonefly is offline   Reply With Quote Quick reply to this message
Old 03-26-2006, 03:08 PM   #4 (permalink)
WIKD 281's Avatar
Member # 33625
Right on man! Thanks for the help. I will start reading!
Old 03-26-2006, 07:23 PM   #5 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
Everything you need to know about CB's.
http://www.cbradiousa.com/faq.htm
One of the great achievements of science has been, if not to make it impossible for intelligent people to be religious, then at least to make it possible for them not to be religious. We should not retreat from this accomplishment.
Salesmen and women. God sells to the ignorant.
SanDiegoCJ is offline   Reply With Quote Quick reply to this message
