SOA Dana 44 ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-30-2006, 10:52 AM   #1 (permalink)
Member # 67403
SOA Dana 44 ?
I need some light shed please....I'm going to put a dodge dana 44 full with out of a 79' in my 89 YJ. The drivers side pearch is molded into the diff. Center to center on the pins is like 33". Do they make off set pearches? I think the springs are skyjacker. Are those o.k.? here's a pic...http://photos.yahoo.com/[email protected]
driveline is offline   Reply With Quote Quick reply to this message
Old 03-30-2006, 11:21 AM   #2 (permalink)
Member # 11973
MORE makes offset perches. I just welded some 1/4" stock to the normal ones and built my own.
Murfman is offline   Reply With Quote Quick reply to this message
Old 03-30-2006, 09:41 PM   #3 (permalink)
Member # 2095
The MORE offset plates only move the axle forward or back
'79CJ5,soa,d44/60,t18,d18w/Obrian 3.6low,5.13's,35x14.5SSR's
'02 Z71
CJ-Jeeper is offline   Reply With Quote Quick reply to this message
Old 03-31-2006, 10:58 AM   #4 (permalink)
Member # 11973
"We now have the special off-set units for the YJ front axle, for those of you who want to do a spring over axle conversion, pictured left"
http://www.mountainoffroad.com/more.htm
select the catalog button on the left, then Axle Mounting Hardware
& Brake lines and scroll down, you will find them.
Old 03-31-2006, 02:55 PM   #5 (permalink)
JDunn's Avatar
Member # 33065
You need to move your springs out side of your frame or you need to shorten the long side of the axle. If you move y7our springs it is a good time to do a shackle reversal.
79' CJ7 Buggy
KI6TLZ
WeBilt 4WD Club
JDunn is offline   Reply With Quote Quick reply to this message
Old 03-31-2006, 03:46 PM   #6 (permalink)
Member # 39371
Send a message via AIM to currupt4130
Those are for the stock dana 30 front axle, his axle has a cast in pad that is part of the pumkin. He can't easily put those in place to narrow it to the correct spring width. The offset is to move the spring slightly over top of the cast where the tub is insterted into the pumpkin
The mountains are calling and I must go.
-John Muir
currupt4130 is offline   Reply With Quote Quick reply to this message
Old 04-01-2006, 09:17 AM   #7 (permalink)
Member # 11973
would have helped if i looked at the pix ;=P
Old 04-01-2006, 02:50 PM   #8 (permalink)
Member # 39371
Haha, I knew what they were as soon as you posted it, RE makes these too and I used them when I SOA'd my jeep originally. I didn't even have to look at the link
-John Muir
Old 04-01-2006, 08:05 PM   #9 (permalink)
Member # 41470
MORE did not have exact offset perch (1/4" offset) that I am looking for so I custom fabbed my perch with deep offset (1") and it work beautifully. All you do is to cut one side off the perch and move this sliced part forward under the perch and weld it on, and weld it on the tube right next to the pumpkin. About 1/2" of top of perch overhang the pumpkin. So far it works well for me.
91 YJ, HP D44, chromo shaft, 8.8, Detroit lock'd 4.88, TeraLow 4:1, Hy Steer, SOA RE Xtreme 1.5", 37" Nitto Mud Grappler, armored
yjsquareyes is offline   Reply With Quote Quick reply to this message
Old 04-01-2006, 10:28 PM   #10 (permalink)
Member # 54975
Send a message via AIM to Plato2k5
i used a 78 ford dana 44 hp axle and the problem i ran into was the spring perches had to go on the pumpkin itself...at the same time i did a shackle reversal system i made myself...so i had to outboard my springs 5/8 of an inch to make the perch sit nice and tight against the pumkin.
this pic shows it at 1/4" ... i found it to be to far inward as i tried to put the perches on my axle... haha
Plato2k5 is offline   Reply With Quote Quick reply to this message
