Engaging Reverse Trouble - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-15-2006, 09:53 PM   #1 (permalink)
Member # 80735
When I try to put my 1994 4.0 25k YJ in reverse at any speed it grinds the gears. Is this normal or a sign of transmission problems down the road?
Thanks,
Chris
cmasfca is offline   Reply With Quote Quick reply to this message
Old 10-16-2006, 01:40 AM   #2 (permalink)
Member # 71580
:eek:
Try putting it in first and then straight into reverse without letting the clutch out. Grinding is "normail" but......... I think it is the " dog teeth"
Adam3000 is offline   Reply With Quote Quick reply to this message
Old 10-16-2006, 07:37 AM   #3 (permalink)
Member # 80735
Thanks, I'll try that today.
Old 10-16-2006, 09:18 AM   #4 (permalink)
Member # 38563
first off, manual or automatic? (guessing manual)
second, why would you be engaging reverse at any other speed than a dead stop?
reverse is an unsynchronized gear in a manual trans and requires the shafts inside to be completely still to avoid grinding
also, your clutch may be dragging when your foot is on the pedal due to misadjusted linkage, leaking master/slave cylinder, or a bad pilot bearing
84' M1031 CUCV 37's, 8kW gen
Pietro is offline   Reply With Quote Quick reply to this message
Old 10-16-2006, 04:20 PM   #5 (permalink)
Member # 80735
Ya it's a manual sorry I didn't specify.
I never try to engage it past ~2-3 mph but even then I forget to stop sometimes and it reminds me
I didn't know reverse was unsynchronized, that explains alot. Thanks!
Chris
