What Transfercase Do I have??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-16-2006, 11:11 AM   #1 (permalink)
Member # 42444
I can't figure out what is wrong with or what shift pattern my transfercase has...
I think it is a 205?
Low range is DEFINITLEY all the way forward (on the shifter)... Then 1 click back/down seems to be neutral.
THE PROBLEM IS one click down/back from neutral SHOULD be 2WD, but for some reason the front driveshaft still spins a little bit... And it doesn't seem to have the 4th, 4WD HI, Position, or at least I can't shift into it... ???
Any help would be appreciated...
THE HUBS ARE NOT LOCKED...
It's not the miles per gallon... It's the SMILES per gallon!
MuddWeiser is offline   Reply With Quote Quick reply to this message
Old 10-16-2006, 11:39 AM   #2 (permalink)
Member # 39045
Uh, some vehicle information would be nice.
Anthony
Yota Tony is offline   Reply With Quote Quick reply to this message
Old 10-16-2006, 11:39 AM   #3 (permalink)
usmc_birthday's Avatar
Member # 75273
Look on the back of your transfercase and see if there is a small steel circle with three bolts holding it to the transfercase. If it does then you do have a 205.
usmc_birthday is offline   Reply With Quote Quick reply to this message
Old 10-16-2006, 12:07 PM   #4 (permalink)
Member # 42444
The vehicle is irrelavent because this isn't stock. If you must know - 75' Blazer.
Sorry - that may have been ambiguous from my original post...
USMC Birthday - am I looking for some sort of inspection plate?
Old 10-16-2006, 12:31 PM   #5 (permalink)
Member # 75273
It is actually the cover that you take off to remove the idler shaft when you need to disassemble the t-case.
Old 10-16-2006, 01:05 PM   #6 (permalink)
Member # 42444
Hmm,
I went out and took a peak at lunch and it has a LARGE CONICAL TAILSHAFT housing that the rear driveshaft hooks to, and off to the right side of that is an inspection plate but it has more than 3bolts holding it on, more like 9 or 10...
Would a picture help?
Old 10-16-2006, 01:58 PM   #7 (permalink)
Member # 75273
Yes,
email it to [email protected]
Old 10-17-2006, 01:41 PM   #8 (permalink)
Member # 42444
figured it out - was a 205 but has nasty oil! gonna change it and see if it works any betteer!
turns out the front shaft was spinning from friction from the oil?
