Fixing threads on YJ Rear Pinion - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-16-2006, 01:26 PM   #1 (permalink)
Member # 26890
Anyone know the thread pattern of the stock YJ rear pinion on a 93? In putting in a new rear yoke, the threads on the pinion go a bit messed up. I've tried running a new nut on it, but it just kills the threads. I tried cleaning up the threads with a dremmel tool, and with a hand file, but I think I'm making it worse. Any suggestions short of new gears? Anyone know the thread size? or where to get a cheap die?
1985 CJ-7 SD-33T Nissan Diesel
1977 CJ-7 236 Perkins Diesel
DieselCj is offline   Reply With Quote Quick reply to this message
Old 10-16-2006, 01:30 PM   #2 (permalink)
Member # 38563
good luck finding a die to fit that
that is heat treated metal, won't be easy fixing the threads on a pinion
you could get a thread file but that would require removing the pinion itself but something tells me they are muffed up bad enough where the file won't work
84' M1031 CUCV 37's, 8kW gen
Pietro is offline   Reply With Quote Quick reply to this message
Old 10-16-2006, 01:31 PM   #3 (permalink)
Member # 68171
Get a thread file...
Knuckelhead
Knuckelhead is offline   Reply With Quote Quick reply to this message
Old 10-16-2006, 01:56 PM   #4 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
A standard 3 sided triangle file can be used to dress up the threads if they are not too boogered up.
guidolyons is offline   Reply With Quote Quick reply to this message
Old 10-17-2006, 10:51 AM   #5 (permalink)
Member # 26890
I see what a thread file is now, never seen one before. Anyone know the thread pitch of the threads? Also anyone know of a local place to get a thread file? Would napa have something like this?
Old 10-17-2006, 05:21 PM   #6 (permalink)
Dabbler
actionpaintball's Avatar
Member # 29562
Send a message via AIM to actionpaintball
Dana 35 should be a .875-20 on stock pinion
actionpaintball is offline   Reply With Quote Quick reply to this message
