YJ TF 999 expert help needed - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-18-2006, 09:04 PM   #1 (permalink)
Member # 76461
Hello all, I have a YJ 4.0L , 35"Procomp, Dana 35 and 30 and my tranny is giving me trouble. When I accellerate there is a vibration coming from it until speed goes higher the vibration goes away and it shift in 2nd. Also sometimes when it needs to go from 3rd to 2nd it does that vibration again until it downshift to 2nd. I have 4" suspension lift with a CV driveshaft and a Slip yoke eliminator so this vibration does not come from the drive shaft. Anyone could help ?
Tristan83 is offline   Reply With Quote Quick reply to this message
Old 10-19-2006, 02:03 PM   #2 (permalink)
Typical White Guy
Member # 9769
Have you checked your u-joints yet? Did the problem appear out of 'nowhere'; or did it show up after you made a certain change?
________
SUZUKI BOULEVARD S50 SPECIFICATIONS
Indyguy is offline   Reply With Quote Quick reply to this message
Old 10-19-2006, 09:50 PM   #3 (permalink)
Member # 76461
Since I made my modif it started slowly and getting bigger. Within 3 month it went from not noticeable to very very noticeable. The weirdest thing is that today it was not doing it at all... My U-joint look fine. The vibration really comme from the tranny. Also when I shift the 4x4 it is almost dissapearing.
Old 10-20-2006, 10:44 AM   #4 (permalink)
Member # 61360
check by chance that when the slip yoke elminator was put it that it was installed right
87 wrangler SOA 4" skyjacker springs dana 60 gm 14 bolt AMC 304 dana 300 and 39.5 Iroks
05 Tj 3" 32" MTs
88 F-350 Tow Rig
ribsyj is offline   Reply With Quote Quick reply to this message
Old 10-20-2006, 10:53 AM   #5 (permalink)
Slapahoe's Avatar
Member # 50068
This happened to me too, I thought my u-joints were f9ine but everything lead to those, so I took them out and sure enough, those little needle bearings were without enough greese for so long they crumbled into dust from the heat.
just a thought.
93 YJ -
Slapahoe is offline   Reply With Quote Quick reply to this message
Old 10-20-2006, 08:10 PM   #6 (permalink)
Member # 56633
check it out.
Check your tranny and motor mounts.
I got some vibes when my tranny mount went out.
YJPep is offline   Reply With Quote Quick reply to this message
Old 10-20-2006, 08:51 PM   #7 (permalink)
Member # 76461
Brand new motor mount and brand new tranny mount
