D35 stock gear ratio 3.55 or 3.73 ?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-20-2006, 08:30 PM   #1 (permalink)
darkenedangel's Avatar
Member # 71459
I'm trying to figure out which is the stock gear ratio on a 94 YJ. I've googled it, went thru pages and pages on this forum searching for the right answer with no luck.
I'm upgrading to a larger size tire from stock and want my speedometer to read correctly, but buying a speedo gear is becoming more complicated than it should be.
Can anyone help me with this?
darkenedangel is offline   Reply With Quote Quick reply to this message
Old 10-20-2006, 08:34 PM   #2 (permalink)
Member # 68595
what motor do you have?? I migt be wrong please corect me if i am but I think the 6 cylinders are 3.07 and the 4 cylinders are 4.11
grtmtbiker is offline   Reply With Quote Quick reply to this message
Old 10-20-2006, 11:15 PM   #3 (permalink)
Vermit's Avatar
Member # 21202
You have several possibilities. See if you have a tag under one of the front or rear diff cover bolts.
If not, just roll the vehicle exactly on revolution of the tire and count how many times the pinion yoke goes around. I.E. approx. 3 1/2 times = 3.55, 3 3/4 times = 3.73. Make sure you have BOTH tires turn one revolution when counting.
Vermit is offline   Reply With Quote Quick reply to this message
Old 10-20-2006, 11:41 PM   #4 (permalink)
Corn_Smuggler's Avatar
Member # 28766
Google says this:
I4 Automatic - 3.73:1
I4 Standard - 4.10:1
I6 Automatic - 3.54:1 (normally)
I6 Standard - 3.07:1, 3.54:1 or 3.73:1
Originally, my '94YJ had 3.07's in the D35 it came with.
-Dan ('63 Willys CJ5)
Corn_Smuggler is offline   Reply With Quote Quick reply to this message
Old 10-21-2006, 01:50 AM   #5 (permalink)
Member # 44951
Send a message via MSN to bobbo27
My I6 auto has 3.07s..
Email jeep with your VIN, they can get a build sheet for you.
bobbo27 is offline   Reply With Quote Quick reply to this message
Old 10-21-2006, 09:31 AM   #6 (permalink)
Member # 71459
It's a I6 manual. Thanks to all of you for your replies. These are the same uncertain answers I came accross. But I will try the tire rotation method since the jeep is sitting on a lift and email jeep anyway.
Old 10-21-2006, 12:24 PM   #7 (permalink)
Member # 28766
You don't have the tag on the rear diff anymore?
