Tire carrier rack - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-24-2006, 10:16 AM   #1 (permalink)
Member # 76501
Tire carrier rack
Hello all. I have a Rock Crawler swing-out tire carrier made by Currie Enterprises. I contacted the manufacturer and they said that they don't make a rack to go on the carrier. Does anyone have this type of carrier that has found a compatible rack? Thanks for any advice.
nealio is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 11:53 AM   #2 (permalink)
Benzz0's Avatar
Member # 22923
somewhat similar to the one I made myself...I am sure you can take some 1" square tubing and make it yourself...
How important is this? I am sure there are folks here that would be happy top make you one, including myself...for the $$$
كافر
Benzz0 is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 12:50 PM   #3 (permalink)
Member # 71973
pm'd you about you building one for me thanks.
Bigstinger is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 08:16 PM   #4 (permalink)
desertsport's Avatar
Member # 39627
Depending on the weight of your tires, and other accessories, you may not want the added weight of the rack and what goes in it. What were you planning to pun on the rack.
35 MTR'S, ALLOY SHAFTS, ARB FRONT AND REAR,4.56
desertsport is offline   Reply With Quote Quick reply to this message
Old 10-25-2006, 08:22 AM   #5 (permalink)
Member # 53188
I also have a home built bumper tire carrier that is similar. I bought an outland rack, the kind that have the basket and carry a jerry can on each side. To fit it up, I welded on risers made from box tubing that just slid over the rack tubing. I then extended the center post of the tire carrier to the height i wanted the rack to support the rack better. Was a simple fix.
here are a few photos that you can see the result.
http://pg.photos.yahoo.com/ph/tomass...?.dir=/cdffscd
Let me know if you would like close up pics, i can take them some for you.
tomass15 is offline   Reply With Quote Quick reply to this message
Old 10-25-2006, 02:11 PM   #6 (permalink)
Member # 76501
I've got 33's. I plan on using the rack for fishing and hunting gear.
Old 10-25-2006, 02:13 PM   #7 (permalink)
Member # 76501
The rack looks good. If it's not a problem, I would love to see a close up of it. How much weight do you think it holds?
Old 10-25-2006, 05:34 PM   #8 (permalink)
Member # 53188
I added some closer pictures to my yahoo pictures.
http://pg.photos.yahoo.com/ph/tomass...m?.dir=cdffscd
One thing to keep in mind when ordering the rack, order the wider one, i got the narrower one and a 33" barely fits and makes it harder to get on the carrier. As for the load it will carry, you will see a piece of aluminum angle at the top of the riser, the load of the rack sits on the riser and the angle bolted in help hold the tilt load. ther weak point of the outland rack is in the leg and tilt weight. I weight 225 pounds and can hang on the rack. I only carry stuff like tent, recovery rope/straps, sleeping bags and that. I try to load the lighter stuff in the rack, since the weight is high. So other than the 2 jerry cans, noting really heavy goes up there.
Hope this helps, Tom
Old 10-26-2006, 10:15 AM   #9 (permalink)
Member # 76501
Tom, Thanks for the pics. and info. It really helps. I'll definitely go with the wider rack.
Neal
Old 10-26-2006, 10:22 AM   #10 (permalink)
phattdraggon's Avatar
Member # 50975
My rack is very similar. same tubing diameter etc. and a rock hard 4x4 trail rack worked great for me (http://www.rockhard4x4parts.com/imag...EAR/063_63.jpg). Trailtoyz on here is the vendor who sells them.
phattdraggon is offline   Reply With Quote Quick reply to this message
Old 10-26-2006, 04:30 PM   #11 (permalink)
Member # 28193
Call Wayne Hanson at Hanson Enterpries. He knows all about the Currie tire carrier. Here ya go. http://www.hansonenterprise.com/
ajfrank is offline   Reply With Quote Quick reply to this message
