Fitting 42's - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-24-2006, 04:17 PM   #1 (permalink)
88Mangler's Avatar
Member # 62271
Fitting 42's
I'm Doing a 14b/d60 swap, and i dont have the cheese to pay for a fuel cell yet so im SOL on stretching, I have 4 inch leaf springs with a 3 inch body lift and 2 inch shackle lift, if i use stock springs sprung over will i clear the 42's?
I really dont want to have to put 4 inch lift springs sprung over with all of this because of the flop formula but i will do what i have to to wheel until i can afford the stretch.....will cutting the fenders in the front pretty much off work out
basically has anyone done this before and what did they do
Thanks
Play: 88 YJ,Dana 60/14B,locked,5.13s,42TSl
Tow: 06MegaCab 2500,Triple Dog Programmer,Straighted
88Mangler is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 04:28 PM   #2 (permalink)
Member # 73191
Find some free XJ springs and flipem backwards, put the stock tank in the bed and cut the shizzle out of the fenders. No on the 4 inch spring over .
jeepinTY is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 04:41 PM   #3 (permalink)
BIG PERM's Avatar
Member # 3993
X2
Stock YJ length + 42's = wheels like shit and flops on command....
Keep your 37's until you get the dinero for the stretch....and stretch it at least a foot to avoid wheelie city.....would advise trimming over massive lift, low COG makes for a much better rig....
Good luck on the swap
SeanP - Never put your penis where you won't put your tongue.
BIG PERM is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 06:34 PM   #4 (permalink)
ne14jpn's Avatar
Member # 42619
Send a message via AIM to ne14jpn
^ X3
-Erik
Miller Motorsports #4421
ne14jpn is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 06:51 PM   #5 (permalink)
88Mangler's Avatar
Member # 62271
ok heres the idea im playing with......an almost free Stretch but first off will the XJsprings bolt into a revolver shackle and will the side that bolts up to the frame bolt into a YJ spring?
This is what im thinking about.......taking out the stock tank and putting it into the back of the jeep then cutting off the eyes of the YJ lift springs leaving a little of the spring on there and then welding them on my crossmember in the rear where the framerails T into the crossmember and bolting the revolver to the eye and the XJ spring to the Revolver.......Yes/no?
Old 10-24-2006, 06:53 PM   #6 (permalink)
88Mangler's Avatar
Member # 62271
and that takes care of the rear but what about the front?........i have a shackle reversal and with my setup now the 36's swing back and hit the tub
should i eliminate the SRS and trim my front ARB bumper or what?
Old 10-24-2006, 07:02 PM   #7 (permalink)
desertsport's Avatar
Member # 39627
Maybe smaller tires for now!!!!
35 MTR'S, ALLOY SHAFTS, ARB FRONT AND REAR,4.56
desertsport is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 07:10 PM   #8 (permalink)
Member # 73191
You could ditch the ARB and buy some useful swag. Those things are huge, sell it and buy some tube fenders and a shorty front bumper.
Old 10-24-2006, 07:13 PM   #9 (permalink)
Member # 73191
Haven't done the rear spring swap but BTF has a kit to weld on the rear of the frame that makes it look easy. I picked up som XJ springs for free. If you don't like the tank in the bed (I did it and it looks fine), just cut a hole in the be and move it up flush with the frame rails and build a box over it.
Old 10-24-2006, 07:19 PM   #10 (permalink)
sand dune coon's Avatar
Member # 57123
lol no shit
sand dune coon is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 07:26 PM   #11 (permalink)
Member # 56164
I put 42 iroks on my yj. Went with R.E. 1 1/2" spring over springs.I made tube fenders for the front and cut the rear fenders. Wheels great no problems with tipping. no stretching done on mine. The shorter wheels base is great for tight trails. try it before you stretch
cowhead5065 is offline   Reply With Quote Quick reply to this message
Old 10-24-2006, 07:56 PM   #12 (permalink)
88Mangler's Avatar
Member # 62271
Thank you!
got any pics?
if you do could you send them to [email protected]
Old 10-24-2006, 07:58 PM   #13 (permalink)
88Mangler's Avatar
Member # 62271
Did you have a 2" shackle lift and 3" body lift?
