4.0 vs 4.2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-26-2006, 10:02 AM   #1 (permalink)
Member # 58336
4.0 vs 4.2
I recently ended up hurting my motor in my 89yj 4.2L Now I can't find any 4.2's locally or at any of the junk yards. I know I can use the 4.0 head on the 4.2 block with some modifications but what do the actual blocks of the 4.0 and the 4.2 have in common? Could I swap out my 4.2 with a 4.0 longblock and just put my carb setup on it? Are the mounts in the same position? Any help would be greatly appreciated.
89yjsofty is offline   Reply With Quote Quick reply to this message
Old 10-26-2006, 03:44 PM   #2 (permalink)
Schmozilla's Avatar
Member # 38562
Send a message via AIM to Schmozilla
I want to say yes, but you are going to need a 4.0 exhaust manifold...The block will physicaly bolt right up where the 4.2 was, but the intake is higher on the 4.0 head than the 4.2 head. Why not just do a 4.0 swap? MPI and all?
Schmozilla is offline   Reply With Quote Quick reply to this message
Old 10-26-2006, 03:46 PM   #3 (permalink)
Member # 40240
Usually cheaper and easier to just swap it for a complete 4.0 The mounts should be the same. You can usually find a used 4.0 for a few hundred dollars.
JeepinDan is offline   Reply With Quote Quick reply to this message
Old 10-26-2006, 08:15 PM   #4 (permalink)
Member # 58336
Theres a local that has a 4.2 complete for $300 it just seems theres no parts for these things anywhere anymore unless it's brand new. I'm thinking I'll get a 4.0 from the junk yard for $125 and throw it all in and when I get around to it pull the 4.2 apart and see what I could use for a stroker down the road.
So the 4.0 will mount up in all the same places but I can't use the 4.2 manifold/carb? I don't want to switch this thing over to efi what so ever if possible. Thanks for the replies guys.
Old 10-27-2006, 09:44 AM   #5 (permalink)
Member # 21815
Why on god's green earth not? The 4.0 will be no better than the 4.2 without the injection.
There are tons of writeup's on doing the swap, injection and all, it's your best bet.
WWDD?
N6YBH
Thanks to
for sponsoring the 2017 Cantina For The Con!
"If you need a tool and don't buy it, you will ultimately find that you have paid for it but don't have it". -Henry Ford
resqme is offline   Reply With Quote Quick reply to this message
Old 10-27-2006, 12:11 PM   #6 (permalink)
Member # 30754
Make sure you get the HO 4.0 from 1991 to 1995. You can use the 4.2 intake with just a small modification to it. The locator dowls on the head will hit the bottom of the intake instead of the holes for the 4.2 head. You just need to grind them enough so that the intake rests on the dowls and the ports line up between the intake and the head.
Get all the FI stuff with the 4.0. If you don't inject it now you might want to down the road. Look at cjoffroad.com, they have a good section just on this subject.
bleoh is offline   Reply With Quote Quick reply to this message
Old 10-27-2006, 09:30 PM   #7 (permalink)
Member # 78867
bullshit the 4.2 it better then the 4.0! why would you even say that? maby cuz its bigger? well not true. well now that i got that out of the way the 4.0ho head will bold right up the the 4.2 block but you will need the intake and the exaust form a 4.0 thats the only probluml. but what the hell if you got a deal on a 4.2 for 300 what are you waiting for stroke that bad boy make it a 5.0 and then slap a blower on it. add a mpi kit and you will be done. email me if you need help ive dont this may times. good luck and i hope to hear from you soon.
superman1456 is offline   Reply With Quote Quick reply to this message
Old 10-27-2006, 10:08 PM   #8 (permalink)
Member # 15668
Quit dancing around and get the 4.0 HO. Either build a stroker or run the 4.0 but run it FI. Get into this century. You will never look back and say " I wish I still had my BBD and all that emmissions stuff."
grljeeper is offline   Reply With Quote Quick reply to this message
Old 10-27-2006, 10:44 PM   #9 (permalink)
Member # 21815
I didn't say the 4.2 is better.
Exercise your critical thinking skills...I said that the 4.0 is no better without the fuel injection. It could be a 2.0 or a 7.0, but if it doesn't breathe right, it won't matter.
Do the 4.0 (because the head breathes better and it has the injection) or a 4.2 with a 4.0 head WITH the fuel injection (same reason). It isn't difficult and you'll be very pleased with the results.
WWDD?
N6YBH
Thanks to
Old 10-29-2006, 03:53 PM   #10 (permalink)
Member # 116
I wouldn't be afraid of the earlier 4.0. That's what I used. The only difference really is smog related. You can use an open air filter for the HO and be smog legal. You need the box for the earlier one. I use an open filter anyway. I don't have to smog in my county.
One positive thing the early ones have is the anti-knock sensor. No pinging problems here.
"The problem with socialism is that you eventually run out of other people's money." - M. Thatcher
SonoraBob is offline   Reply With Quote Quick reply to this message
