V8 TJ Build up....axles? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-16-2006, 11:51 AM   #1 (permalink)
Member # 41964
I am in the middle of building up my TJ. I payed it off in June and pulled out the motor and tranny for a swap. Found a 5.2L and 44re out of a 97 ZJ at a local yard and brought my 2.5/ax5 in for a swap. $350 and a few hours later I had a V8 swap for my TJ. I just finished the swap and am looking for ideas for axles. I am going to run 36s and drive the hell out of it, on and off the road. I was looking at a 8.8 or 44 for the rear and a reverse cut 44 for the front. Question is would they hold up?
wahzoo is offline   Reply With Quote Quick reply to this message
Old 11-17-2006, 11:03 AM   #2 (permalink)
Member # 49539
Send a message via MSN to BCYJ
D60 it if your going to beat the hell outta it(Do it right the first time!), If your going to build 44's then Chromo's and CTM's will probably be nessecary.
IMO
4cyl YJ 33/12.5 BGF AT K/O's, RE4.5ED, AR 767's, Boomerangs, DT Shocks, What Swaybar? AA HD SYE,8.8/LS and 4.88's, HPD30 4.88's, 1750 KG's with all my junk.
BCYJ is offline   Reply With Quote Quick reply to this message
Old 11-17-2006, 12:27 PM   #3 (permalink)
Member # 39045
I'm the type of person that believes in doing things once.
So I'd way 1 tons, however, you'll need rubber bigger then 36".
Anthony
Yota Tony is offline   Reply With Quote Quick reply to this message
Old 11-17-2006, 12:55 PM   #4 (permalink)
Member # 37109
I say this to everyone who asks, and i hear it from most people who swap them in: Don't waste your money on 1/2 ton axles. I haven't even finished my build and i wish i'd gone 1-tons.
RockcontrolXJ is offline   Reply With Quote Quick reply to this message
Old 11-17-2006, 02:44 PM   #5 (permalink)
00pumpkin's Avatar
Member # 38716
Go 1-tons and run 37's instead of 36's.........
America is all about Speed. Hot, Nasty, Badass Speed......
00pumpkin is offline   Reply With Quote Quick reply to this message
Old 11-17-2006, 02:57 PM   #6 (permalink)
Member # 73191
Mog 404's
jeepinTY is offline   Reply With Quote Quick reply to this message
Old 11-17-2006, 03:33 PM   #7 (permalink)
Member # 41964
Reason I am looking at the 1/2 ton axles is two fold. PRICE and since I am only going to run 36s or mabe even 35s I don't want to give up any more ground clearance than I have to. I dont mind changing a few shafts here and there and obviously ANYTHING will break.
Old 11-17-2006, 03:49 PM   #8 (permalink)
Member # 20569
Regardless of anything anyone tells you "you can not put 10lbs of shit in a 5lb bag" You will spend a bunch of money building 1/2 ton axles pony up and get 1 tons.
Sommertime Motorsports #678
sommertime is offline   Reply With Quote Quick reply to this message
Old 11-17-2006, 06:24 PM   #9 (permalink)
Member # 77245
go with the 60's
PizzaFarno is offline   Reply With Quote Quick reply to this message
Old 11-17-2006, 06:28 PM   #10 (permalink)
Member # 65332
60 rear, 44hp front, 36's be ight
fishotro is offline   Reply With Quote Quick reply to this message
Old 11-17-2006, 11:28 PM   #11 (permalink)
Member # 81686
Go Big or Go Home
If you're gonna beat the piss out of it on (I'm assuming drunken) occasion, go with 1 ton if you want cost effective. Even if you do beak the odd 1 ton part it is worth the money to make it even more bombproof than before. Otherwise you'll spend shitloads of money building the half ton stuff to hold up. I realize there are exceptions, but that depends on driving style and whether or not you'll use lockers. If you do go half ton and use a locker, go with a selectable so you can open the diff when gravity possesses your right foot. I hope you make the right choice, Cheers!
TJT-Rav is offline   Reply With Quote Quick reply to this message
