running light/dash lights help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-21-2006, 09:08 PM   #1 (permalink)
Member # 23282
i lost my running lights and dash light. has this happen to any one elso.in a 1997 tj.does anyone have any info on fixing this problem.is it a fuse behind the glove box.any info can help.
thanks
fuck you I am a noobi
39bogger is offline   Reply With Quote Quick reply to this message
Old 11-22-2006, 03:36 AM   #2 (permalink)
89breaker's Avatar
Member # 64213
Mine is a YJ but.......
Dude, go pickup a Haynes/Chilton Manual or better yet a factory shop manual (forget the technical term for the last, I am sure someone will correct me).
Read it & look at the wiring diagram before you start.
Bottom line, use this as a chance to build up a links database.
I'll toss a cookie, check your fuses.
89breaker is offline   Reply With Quote Quick reply to this message
Old 11-28-2006, 10:34 PM   #3 (permalink)
Member # 23282
bump still looking for help here
Old 11-28-2006, 10:39 PM   #4 (permalink)
Member # 73191
Originally Posted by 89breaker
....I'll toss a cookie, check your fuses.
There is your help, there is a reason they both are on the same fuse
jeepinTY is offline   Reply With Quote Quick reply to this message
Old 11-29-2006, 09:31 PM   #5 (permalink)
Member # 23282
do you know what fuse it is there is about 30 fuses.and the lowcation.
Old 11-29-2006, 09:38 PM   #6 (permalink)
Member # 82521
The fuse box cover should have a picture or a schedule showing what fuse is which, or just look for one that looks burned out. If itís not a fuse, look for a break in the ground. 99% of the time electrical problems come back to the ground.
Kriss
Saddle Tramp is offline   Reply With Quote Quick reply to this message
Old 11-29-2006, 10:00 PM   #7 (permalink)
Member # 73191
Not to beat a dead horse here but you really should get a manual. I can't remember if my YJ's had the diagram on the glovebox or not but my TJ does. If it doesn't, start pulling
Old 11-29-2006, 11:30 PM   #8 (permalink)
Member # 65332
my cj "switch" was loose, causing the lights to flicker. the bad fuse is the one with the blown wire...
fishotro is offline   Reply With Quote Quick reply to this message
